Author Topic: xbr500 oil  (Read 536 times)
guest1783
xbr500 oil
« on: May 14, 2014, 09:45:27 AM »
hi guys time has come to try and start the xbr500 that I've rebuilt from a box. just wondering if anyone has advice on what oil is best to use cheapest preferably
Re: xbr500 oil
« Reply #1 on: May 14, 2014, 10:07:28 PM »
Aye pete9263,
If you select 'Technical' and then enter "oil" into the 'Search' box in the top right of the screen, you should get a great list of posts on the oil debate.  ;)
Used to use Halfrauds car 10/40 semi-synthetic in SRX600 and Honda Bros400, also some inexpensive 10/40 semi-synthetic from a motor factors. Both seemed alright for the motor, but the additives lead to clutch slip, especially with the SRX when changing into 5th, having wound the bike up to 5.5K - 6K in fourth and then popping it into top. Lots of nurse and feed with the throttle. After cleaning the plates with brake cleaner and then re-filling with Halfrauds motorcycle 10/40 semi-synthetic no problems. Now use Morris 10/40 semi-synthetic for motorcycles, bought in the 25litre drum delivered to the door for £99-00 [Fleabay]!  :'(  :o But no further problems and the motors are looking good.
I hope this helps.
guest1783
Re: xbr500 oil
« Reply #2 on: May 15, 2014, 06:18:51 PM »
thanks for the info actually bit the bullet and bought some halfrauds 10w40 mc oil
