Technical
Bike Problems/Questions
xbr500h 1988
Topic: xbr500h 1988 (Read 855 times)
guest1783
xbr500h 1988
April 11, 2014, 04:20:22 PM »
hi there
can any one tell me if the exhaust on the 500h is one piece or two
cheers. wont bodge and wont reach rear bracket
cheers pete
guest1733
Re: xbr500h 1988
April 11, 2014, 05:29:47 PM »
If it is an original it is definitely two parts. I recently removed mine to fit new seals and clamps and could not get it to fit when I put it back, I found that I had left the old seals inside the cylinder head, once removed, Bingo!
GrahamH
New Member
Re: xbr500h 1988
April 12, 2014, 07:00:22 AM »
The XBR500H had a one piece system, i.e. the silencer welded to the downpipe. The early models had seperate parts.
GrahamH
guest1783
Re: xbr500h 1988
April 12, 2014, 10:02:53 AM »
cheers guys
they look like they are two piece so will try the old block of wood and rubber mallet technic to split them
chris22
Jr. Member
Has anyone seen the plot?
Re: xbr500h 1988
April 12, 2014, 03:20:03 PM »
My XBR500 H has front pipe and silencer as one piece - though it looks like they could be split they can't.
Re: xbr500h 1988
Reply #5 on:
April 12, 2014, 06:47:46 PM »
I had this problem with my left side silencer not apparently lining up with the mounting holes.I had to sweat and swear to get it back on!
guest1783
Re: xbr500h 1988
Reply #6 on:
April 15, 2014, 12:54:59 PM »
welded fiddlesticks
but I will not be beaten
Technical
xbr500h 1988
