Author Topic: SRX 400 fork problem  (Read 428 times)
guest1797
« on: March 23, 2014, 02:35:21 PM »
Hi All
I have recently rebuilt a set of forks, no matter what i do i get an oil weep from the pinch bolts. I have tried new copper washers on the bolts, tried gasket sealant with new washers, and the pinch bolts are really tight , but still it weeps from both sides. All the components were spotlessly clean too. Anyone else had this and what did you do to cure please?
Thanks
Dave
Re: SRX 400 fork problem
« Reply #1 on: March 23, 2014, 06:39:51 PM »
When you say pinch bolts do you mean the bolt which screws into the bottom of the damper rod. When you say they are really tight did you use a tool to stop the damper rod rotating ?.
Have you checked to see if the slider is cracked ? Apart from that do the forks work as expected ?
