Just lifted the cam cover, plenty of oil still inside, the cam and rockers are in good condition, so thats one thing less to worry about. All I need to do is investigate the oil pump problems.
Is it possible to get an air lock in the pump after the oil system has been primed ?.......If it is then this could be the cause of all the ruined heads that I have heard about from XR XL and XBR owners, even ones that are well maintained and the oil checked regularly.
I measured the oil taken out of the engine and it was spot on, I have spun the pump by hand and it seems to be flowing ok, but I will change the O rings and see if that helps.
Anyone with any ideas on whats happened ? as its all a bit of a mystery at the moment
