Author Topic: xbr - recut valve seats  (Read 806 times)
guest1540
« on: August 17, 2012, 11:25:17 PM »
Hi, I have read elsewhere on this site about the benefits of re-cuting the valve seats on an xbr with the objective of curing engine stall on tickover. Why is this necessary - are the origional cuts wrong? What dose this involve, just freshen up the seats and re-grind the origional valves? Any advice much appreciated.
Re: xbr - recut valve seats
« Reply #1 on: August 18, 2012, 07:47:42 AM »
Engine stall on tickover is due to a poor idle mixture. The valves have nothing to do with it, assuming they're in good nick and adjusted to spec. Beneath the carb is a tiny, hard-to-adjust idle mixture screw. Because it's close to the gearbox housing you can't get a proper screwdriver to it but a small screwdriver bit shoved into a bit of rubber hose will do the job. Try turning it out 1/4 turn. I think that does it, but you may need to play around with it.
« Reply #2 on: August 18, 2012, 10:00:21 AM »
The problem was never with the valve seats. As GB500NZ says it was mostly a mixture problem though Honda did release some revised valve clearances later models which was supposed to help.  I also use an Iridium spark plug - NGK    DPR8EIX-9 - which also seems to help. In the end it's something you get used to and just keep the revs up a touch at tickover.  I wouldn't take the head off unless you need to as you'll probably find you have a crack from the plug to the valve seat ....most XBR's do and usually you can ignore it.
« Last Edit: August 18, 2012, 10:09:34 AM by SteveC#222 »
guest1540
« Reply #3 on: August 18, 2012, 06:29:53 PM »
Thanks for the advice on this problem Guy's. Idle screw adjustment and a plug change sounds a lot less hassel than a head off job!
