Author Topic: XBR Bars.  (Read 610 times)
J.Y.Kelly
XBR Bars.
« on: June 24, 2012, 05:44:29 PM »
The XBR I am restoring has a damaged r/h clip-on/handlebar. The end is chewed up so it has obviously been dropped. I am a tall guy and find the tucked up riding position is made worse by the bars. Is there an option to fit something slightly raised from another machine?
Kelly.
Re: XBR Bars.
« Reply #1 on: June 29, 2012, 08:17:33 PM »
Aye J. Y. Kelly,
Put "XBR handlebars" into the search engine in the top right of this page and you should be able to read this and more:
"Bike Problems/Questions / Re: XBR: bar risers advice needed
« Message by SteveC#222 on October 22, 2009, 09:32:37 PM »
As far as I know Honda CBX550 F2 handlebars fit straight on.  Most of the XBR cables will still fit but you may need to carefully re-route and check throttle cables are not being pulled on full lock.  I think you may have to replace the choke cable - you may have to make one up.
Gives a useful rise over the standard bars."
It's a start and other maybe along soon to chip in their pennyworth. Hope you find what you are after.
Regards, Bill.
