Author Topic: XBR Exhuast Brackets/Holders?  (Read 727 times)
Liam
« on: April 08, 2012, 09:14:38 AM »
Hey Guys,
Does anyone know where i can get hold of a set of exhuast brackets for XBR (the part that bolts to engine block)
Cheers!
Liam
Re: XBR Exhuast Brackets/Holders?
« Reply #1 on: April 08, 2012, 12:34:30 PM »
Hmmm...I would have said David Silver or Wemoto but both show them as discontinued :-\  You may be able to get them from one of the German sites and they wouldn't be that hard to make if it came to it.
Part no is - 18231-mk4-000
Liam
« Reply #2 on: April 09, 2012, 07:00:24 PM »
Hey thanks for the part no, ive had a look around cant seem to find them anywhere.
Does anyone know if any other bikes might use same part? or anyone who is capable of making a pair? i need the hole to be 35mm and 58mm from centre of bolt to the other.
thanks guys.
Liam
« Reply #3 on: April 11, 2012, 11:01:01 AM »
Liam
         Do me a sketch (Including ALL dimensions) of what you want and what metal you want it making from (including the thickness)  and email it to me along with your address. I may be able to help if I have the info.
Ian :)
« Last Edit: April 12, 2012, 11:34:27 AM by ian650 »
tj63
« Reply #4 on: April 11, 2012, 03:20:34 PM »
I just Googled the part number and got this:
http://www.hondaoriginalparts.com/honda_motorcycle_parts_selection.php?block_01=13MK4F21&block_02=F__2000&block_03=6910
Looks like a standard exhaust flange, like we used to make thousands a week of where I used to work.
Trevor
« Last Edit: April 11, 2012, 03:24:30 PM by tj63 »
