Author Topic: SRX400 tyre choice  (Read 1337 times)
guest1378
SRX400 tyre choice
« on: November 23, 2011, 10:54:23 PM »
Hi everyone!
Yesterday I won an SRX400 on ebay.  Hurrah!!!  I'm not collecting it until Sunday though.
The seller states that it needs a new front tyre (current one is on legal limit) - does anyone have any tyre recommendations please?
Thanks.
Hazel
Re: SRX400 tyre choice
« Reply #1 on: November 24, 2011, 12:14:30 AM »
Aye sfb,
Welcome and congratulations! :)
Bridgestone BT45 or Avon RoadRider. Haven't tried Continental, but not heard bad spoken. Dunlops are good, but maybe wear a bit quick, K82 under 3,000 miles on the back afore the canvas showed! ::) ::) ::) Metzeler/Pirelli, I used to use, until rapid wear, variable wear and delaminating tread from the carcase and some wee slides changed my opinion! :( Maxxis if you can get them do good mileage, but can be a bit on the hard side and skaty in cold wet weather.
Hope you enjoy the SRX.
« Reply #2 on: November 24, 2011, 11:28:13 AM »
My main recommendation would be to stick with the stock sizes, oversized tyres mess with the handling.
tj63
« Reply #3 on: November 24, 2011, 12:40:12 PM »
Bridgestone BT 45, definitely.  Sizes and pressures are:
F110/80 H17  2.3 Bar
R12080 H18  2.5 Bar
Trevor
« Reply #4 on: November 24, 2011, 01:15:35 PM »
Earlier twinshock models have different sizes. Details can be found HERE
guest1378
« Reply #5 on: November 24, 2011, 05:48:49 PM »
Thanks!  That gives me some good ideas to start with, I'll check out the prices and sizes later.
« Reply #6 on: November 24, 2011, 11:18:13 PM »
Aye sfb,
I cannot emphasise enough the importance of Steve's comment above and his recommendation that you check the tyre sizes for the earlier twin shock model.
A 110/80 H17 on the front of 'Sally' SRX600 1986 (had the 1987 3 spoke alloy wheels fitted from a SRX400), made her roll like a drunken sailor on shore leave, on banding, tar joints, linear abraded surfaces and worst of all, the tramlines/ditches/canals created on worn out roads by 'Super-single' lorry wheels.
Re-fitting a standard 100/80 H17 made a completely confidence inspiring front end return. No weave or wander and rapid steering.  :)
Check your pressures every time you go out, a couple of points out in Bars or psi will make all the difference.
'Super-singles' is a rant subject in my opinion and I need the shut eye tonight! >:( So will say no more.
All the best, Bill.
guest1378
« Reply #7 on: November 27, 2011, 04:37:42 PM »
Well, it's currently got an Avon Roadrider rear tyre and a BT45 front.  The front needs replacing soon so I suppose the obvious thing to do is get a Roadrider to match the rear?
I think RoadRiders are what I've got on my little Tribsa and they seem good. Equally, the BT45 were good when I had my W650.
guest1378
« Reply #8 on: September 01, 2013, 05:34:05 PM »
Ok, sorry to go back to this one - my tyres got through last years MOT but now definitely need replacing - the rear one is showing cracks in the sidewalls.
The link above says I should have Front 100/80-18 and Rear 120/80-18
M&P recommend Avon Roadriders in 100/90-18 and Rear 120/90-18.  Is this the size other owners of twinshock SRXs are using ?
« Reply #9 on: September 01, 2013, 08:06:38 PM »
If you're on a twinshock... then stick with the stuff SteveH posted... any deviation from that has in my experience been a retrograde step
120/80/18 rear
100/80/18 front
I've found nothing better than Bridgestone BT45's and I use 30psi front and back
« Reply #10 on: September 02, 2013, 06:02:14 AM »
120/80/18 rear
100/80/18 front
I've been using em on my old Beemer and I wouldn't be easily swayed away. The grip is great wet or dry and no issues with regards to what can only be described as "feel". They may be a tad wider, size for size, than other brands. Pressures I run are to the original recommendations, wear rate is a bit of a downer for me, but the grip and feel outweigh that. They heat up nic and quickly.
« Reply #11 on: September 02, 2013, 10:06:55 AM »
BT45s for me...
« Reply #12 on: September 02, 2013, 11:59:30 AM »
With Avon you need to mount a 90/90/18.
The 100/90/18 is too high and it will touch the front fender rivets. Then the rivets will chafe and your fender will vibrate and touch the tyre. So you'll have a ruined fender (split on the front), ruined rivets, and a tyre with two new lines engraved on the rubber...
I haven't experienced it personally, but many french (and swiss) SRX owners had this bad idea.
Moreover it will give you the impression to ride a truck because it's too wide. Avon are good tyres whatever conditions.
BT45 are very good but the front tyre have a funny way to use. It doesn't interfere with security but you can feel very slight vibrations.
« Last Edit: September 02, 2013, 12:06:31 PM by SRXweb »
guest1378
« Reply #13 on: September 07, 2013, 10:52:44 AM »
Thanks for the replies, great advice as always  :D
