Author Topic: GB500 question  (Read 552 times)
GB500 question
« on: January 30, 2007, 02:24:54 AM »
This might seem like a stupid question, but where is the engine oil drain bolt located on the standard GB motor?
I only ask because the hole in the crankcase where the XBR bolt is located seems to be blocked off on my GB motor.
GB500nz
Re: GB500 question
« Reply #1 on: January 30, 2007, 08:21:40 AM »
At the bottom of the oil tank on the righthand side and just below and aft of the oil filter. 12mm spanner. If you let it idle for a minute or so on the centrestand, most of the oil will be in the tank. Mind the aluminium sealing washers: sometimes they stick to the casting then fall off into the hot oil.
Re: GB500 question
« Reply #2 on: January 30, 2007, 09:30:40 PM »
Ahhh... I see. On the XBR it is on the other side of the engine, half hidden behind teh lower frame rail.
Much appreciated, thanks
