Author Topic: HONDA CB250RS REAR WHEEL BUSHES  (Read 897 times)
DIB
« on: July 13, 2011, 09:07:51 PM »
Does anyone know of a supply of the rear wheel bushes on my CB250RS or indeed if bushes from another model may fit?
Regards
Re: HONDA CB250RS REAR WHEEL BUSHES
« Reply #1 on: July 13, 2011, 10:23:21 PM »
Bushes as in bearings?
Try Wemoto.com
http://www.wemoto.com/bikes/Honda/CB_250_RSA/81-84/
« Reply #2 on: July 14, 2011, 08:24:45 AM »
They should be sealed ball bearings. Measure the spindle diameter and the bearing's outer diameter and go to your friendly neighbourhood bearing shop for a set.
« Reply #3 on: July 14, 2011, 06:53:51 PM »
i think he means the round rubber bushes that they use as cush drives on the little honda.
Dick Scratcher
« Reply #4 on: July 14, 2011, 08:29:41 PM »
No Idea Dib but if you do get any how the Hell are you going to get the old ones out ?, 'blind' holes +thirty years in position !. Any ideas, if so let me know, mine are getting sloppy.
DIB
« Reply #5 on: July 15, 2011, 04:53:53 PM »
Yes it is the rear rubber bushes that the sprocket bolts go into too, should have been more clear; must have been the cider!
If I can get some I will get them out no probs! & let you know.
regards
