Author Topic: FZR400  (Read 909 times)
FZR400
« on: July 08, 2011, 07:40:33 AM »
Does anyone have an FZR400 sprocket carrier they could take a few measurements from ?.
guest1155
Re: FZR400
« Reply #1 on: July 21, 2011, 05:24:32 PM »
I could probably lay my hands on one. What do you need?
Re: FZR400
« Reply #2 on: July 25, 2011, 12:25:10 PM »
Cheers for that. I think there are a few FZR carriers, the one I am thinking of would look like this on the back.
The measurement I am looking for is the height of the casting which holds the studs, so from the sprocket mounting surface to the bottom of the post. If you look on the left of the picture you can see the casting which holds the sprocket mounting stud protrudes from the main body. Its the height of this post I need.
« Last Edit: July 25, 2011, 12:28:46 PM by Steve H »
guest1155
Re: FZR400
« Reply #3 on: July 25, 2011, 07:28:36 PM »
i'll see what i can dig out. won't be till the weekend tho. New wheels for the srx?
Re: FZR400
« Reply #4 on: July 25, 2011, 09:03:44 PM »
Cheers, yep they are destined for my project SRX but I need to get the chain alignment correct, I have carriers that are either 10mm to far out or or 10mm to close.
Steve
Re: FZR400
« Reply #5 on: July 25, 2011, 09:29:39 PM »
10 m/m out seems to have a familiar ring to it Steve!
(Monoshock/twin shock engine difference in chain alignment)
Re: FZR400
« Reply #6 on: July 25, 2011, 10:04:49 PM »
SZR carrier is too far our, TZR250 carrier too close, I am hoping the FZR400 is in the middle.
guest1155
Re: FZR400
« Reply #7 on: July 26, 2011, 06:02:57 PM »
hopefully i'll find the ones that used to beno my bike. If you're using a standard swingarm it should all work except for the brake caliper mount would need to be modified and i might eve have one of them kicking about too. Personally, i would (and in fact have) go down the suzuki back wheel route for the better tyre sizes.
guest1155
Re: FZR400
« Reply #8 on: July 30, 2011, 05:45:20 PM »
23mm. hope this helps.
Re: FZR400
« Reply #9 on: July 31, 2011, 09:11:08 AM »
Excellent thanks for that
Steve
guest1155
Re: FZR400
« Reply #10 on: July 31, 2011, 05:36:21 PM »
no worries. i do have the carrier if you need it.
