Author Topic: srx400 cylinder bore and piston specs  (Read 689 times)
guest668
« on: April 09, 2011, 06:14:45 PM »
hi i need to check the bore of cylinder and check for piston wear etc...does anyone know what the correct wear limits are....am i ok to go by limits shown in the srx600 workshop manual?
Re: srx400 cylinder bore and piston specs
« Reply #1 on: April 13, 2011, 08:38:10 AM »
Sorry I dont have this info. I would have expected the 600 piston clearances to be greater than the 400.
Steve
guest668
« Reply #2 on: April 13, 2011, 11:22:31 AM »
thanks Steve i expect the same but cant find the specs i need anywhere....
« Reply #3 on: April 13, 2011, 07:04:46 PM »
Aye beezer764,
This link maybe of use: 'SRX4-6-SpecTable'
You can also download the SRX600 workshop and owners manuals from this site if you wish.
My 'gut feeling' would be to end gap the rings as normal, allowing for the same ratio of end/side gap as that for the SRX6.
Pages from SRX6 manual that you need to see are 3-28 & 3-29. If you can't find them, PM me and I will attach them to my reply.
Hope this helps.
« Last Edit: April 13, 2011, 07:06:41 PM by themoudie »
« Reply #4 on: April 13, 2011, 07:40:24 PM »
You could try this http://www.bikechatforums.com/viewtopic.php?t=63414 he has an XT400 manual listed. I believe the SRX400 and XT400 engines are similiar.
