Author Topic: 86 Yamaha XT 350, Starting, Throttle hanging on,  (Read 626 times)
Baldrick
« on: June 29, 2010, 10:30:26 AM »
Hi everybody, new member here,
I have recently acquired an 1986, XT 350,     Anybody know the correct procedure for starting from cold.       Also when warmed up the throttle hangs on at about 2000 revs when I come to a halt, it will drop back if I just blip it a couple of times, I have checked the shut off cable, and the primary carb piston is not sticking open.
Regards Baldrick, Xt 350, CB250RS, and plethora of MZ's
Bojer
Re: 86 Yamaha XT 350, Starting, Throttle hanging on,
« Reply #1 on: July 05, 2010, 01:06:43 PM »
HI
I'd suggest you thoroughly check the state of the intake rubbers - they often persish and make starting hard and give a weak mixture which could explain both problems .
Best of luck !
Baldrick
« Reply #2 on: July 06, 2010, 09:58:46 PM »
Thanks for that Bojer,
 intake rubbers look Ok, but while I was down there noticed that the throttle spindle nut was only finger tight so got a 12mm spanner on it and hay presto now I have got a proper throttle !!!!!!!!!!!
Cheers,   Baldrick, Xt 350, CB250RS, and plethora of MZ's
