Author Topic: SRX600 3SX monoshock drive sprocket removal  (Read 595 times)
M4S4
« on: May 21, 2010, 08:29:54 AM »
Hi, I'm having difficulty removing the drive sprocket from my SRX 600 3SX. Tab washer & single holding nut came off OK but even using a puller I cannot seem to shift the sprocket off the splines. Does anyone have any knowledge of what might work here?
Any thoughts appreciated.
By the way the post recommending B&C Express is spot on, very helpful and fair pricing.
Re: SRX600 3SX monoshock drive sprocket removal
« Reply #1 on: May 21, 2010, 10:27:40 PM »
Aye M4S4,
I suspect the sprocket has siezed onto the splines due to rust.
PlusGas A, Diesel or 3in1 penetrating oil any one of which will work, soak the splines and sprocket. Give the spocket a hitting with a 1lb hammer round the circumference of at the base of the teeth, with short, sharp, strokes, your try to vibrate and loosen the assembly, not drive it through the cases! ::) If this doesn't start to slacken the sprocket.  ???
Get a blow torch or some heat and warm the sprocket around the shaft, NOT THE SHAFT, give it another hitting and some more diesel etc. Repeat. If still reluctant, leave diesel to soak for 24 hours, then apply more heat and vibration with iced water after.
If this still refuses to shift, disc cutter out and split the sprocket from both sides toward the shaft and finish off with a sharp cold chisel! :o Desparate!!!!!
All the best and there maybe a load more suggestions to come from the bodgits! ;) Bill.
« Reply #2 on: May 22, 2010, 02:33:31 PM »
I think Bill has got it all covered...he must have had previous experience of this !!
« Reply #3 on: May 23, 2010, 09:19:00 AM »
Are you strikingthe end of the puller with a hammer. I generaly tighten the puller, hit it a few times, tighten again, and repeat, you might only be able to move the puller bolt a few degrees at a time but it wil slowly drag the sprocket off.
Remember to protect the end of the shaft to stop it splaying out!.
