Author Topic: ATW byCB500?  (Read 1210 times)
OMEGAMAN
ATW byCB500?
« on: July 21, 2009, 09:09:00 AM »
 Thought I might as well start a report on here about the task ahead! As some of you already know, due to my personal situation, I have come to a decision, it's time to stop dreaming & actually get on with it!
Off around the world (taking as long as I want!) on an old, tatty CB500 (sitting outside under a plastic sheet)  SEE PHOTOS in project section!
   Plans are now underway, stuff is being sold to fund it, checks & enquiries being made & lots & lots of reading research.
   I will update here as & when there is enough progress to be of interest! ::)
  Check thread in forum chatter (up & away!)
OMEGAMAN
Re: ATW byCB500?
« Reply #1 on: October 05, 2009, 06:28:13 PM »
 Bit of an update, now that something seems to have been done at last!
 Bike (CB500R 94)  put in garage & most parts taken off for inspection &/or replace
 Whole swing arm assy taken apart & cleaned, all looks ok including swing arm bearings, now ready to re-assemble (including new chain & sprockets DiD)
 Pleased when Boyd found a "touring" Scott oiler fitted under the numberplate.
 Steering head bearings re-greased & re-fitted as they seem ok! (spare ones to be taken)
 Forks were too far gone £?  so replaced via e-bay for £75 (good chrome)
 Fork gaiters fitted at same time (a must!)
 Front wheel cleaned & checked all ok including bearings, but disc, although not much wear, had a lot of hairline cracks around the holes (see photo) so brand new one obtained for £39+p&p.
 Front brake stripped & cleaned (inc. pistons) & pads were scrubbed clean of oil! all back together now & seem to be fine.
 Mudguard seems a little close to tyre & might cause problems when stones & mud start to stick to tyre, so the motocross one in pic might work better?
 Front tyre is off my old race bike, (& should see me to Sudan?) or thereabouts, where some dual purpose tyres should be waiting at a pre-arranged place?
 Clocks check out ok as does the ignition barrel & wiring.
 New throttle grip fitted & cables oiled (new clutch cable too!)
 Picked up a couple of hand guards off e-bay, in the process of fitting!
 Same with a set of engine guards (which will prove invaluable!)
 Rear wheel off e-bay (came in a job lot) & fitted with a s/h tyre from breakers for £20.
 Which head lamp to fit????     MMMmmmmmm?
 A few bars & brackets have been roughly painted with the first tin of paint to hand (Gold!) & might come in useful when bribing officials?
 I bought a Givi touring screen but think it is a bit to heavy (unneccessary?) so will make one up from an old race screen (fitted the wrong way up?)
 The exhaust is a Motad system, which seems to be in good solid condition (had to have the bracket braised though) & should be fine?
 Plan to make & fit a bashplate (not much ground clearance, but I think it will be needed as the sump is very vulnerable)
 The sidestand has a slightly bigger foot now!
 Rear shocks are new Hagons (fitted with heavier springs as they will be working hard!)
 Any questions???????????????????????
Re: ATW byCB500?
« Reply #2 on: October 06, 2009, 09:00:35 AM »
Nope!  But I think this is great John, keep on with it!
Is SimonB going with you then??  Or am I getting confused?
OMEGAMAN
Re: ATW byCB500?
« Reply #3 on: October 07, 2009, 01:56:19 PM »
 Hi Andy,
                Yes!  can't get rid of him!  he seems keen on the project,  & time will tell, but as I have said to him, he's very welcome & it will be great to have good company for many reasons,  but I will always be planning & equipping to go alone!  Just in case!
 Also, with us both being novices at this, there will be many problems ahead &  one or the other may well decide to quit, & so both really need to be equipped for solo riding.
 Biggest problem is the money,   looks like I will only be leaving with around a couple of grand?  having all sorts of problems with the council & the like!
