How easy is it to change the linkage bearings ?
Its a c*nt!!
theres a spherical bearing in the "rocker", and I bought mine from MZ (BSA-Regal) who are now no longer impoters. I spose you can get it from a bearing supplier, but they're not very cheap (about £37 or something daft like that).
Also, if you've just changed the front wheel (and bearings) I had a funny thing once at a trackday at Cadwell. There was scrutineering
and he said wheel the front bearings were gone. I knew they were fine, but the pinchbolts and the spindle were loose. We had a laugh, but it makes a couple of points:
1. Scruteering is not a bad thing!
2. I'm not a great meachanic
3. Check the front spindle!
Is the rear wheel aligned ok? I had a bad off after a big tankslapper on my skorpion. I subsequently checked it over and the head bearings were gone, also the front wheel bearings. Wasn't long before I did the rear bearings (wheel, sprocket carrier, linkages, shock bearings). The swingarm bearings were ok on mine (then, probably knackered now!!)
