Author Topic: XBR filters  (Read 752 times)
guest288
XBR filters
« on: November 11, 2007, 10:24:54 PM »
Hi Guys,
Can I get rid of the standard Airbox and replace the air filter with a pancake filter? If so, what/how do i sort out the crankcase breather? Can I replace that with a stand alone breather? If I replace the air filter, I'll probably need to change jet sizes- anyone done this and know what sizes i'll need???
Cheers Dave.
danny baker
Re: XBR filters
« Reply #1 on: November 14, 2007, 09:37:03 AM »
I've got rid of mine. Breather pipe routed down below the frame. Ramair filter on the carb.
But you will have to change the main jet.
guest288
Re: XBR filters
« Reply #2 on: November 14, 2007, 07:51:52 PM »
Cheers Dan
Would re-routing the breather pipe to below the frame pose a risk to dropping oil on the ground just before the rear tyre? Would i be better off using a breather filter? Also, what type of ramair filter have you got on the carb?
Dave
danny baker
Re: XBR filters
« Reply #3 on: November 19, 2007, 08:34:40 PM »
I think it's a 62mm made by Ramair
