Author Topic: Cramp Buster?  (Read 858 times)
John B
Cramp Buster?
« on: September 06, 2006, 10:00:18 AM »
Anyone had a go with this 'cruise control'?
http://www.scottoiler.com/thecrampbuster.asp
beeman
Re: Cramp Buster?
« Reply #1 on: September 06, 2006, 03:21:52 PM »
I use a simular device on the srx having first used one in the states a few years back.
Good points is that no "white finger" develops after rides and is easy to use, as it is low tech.
Bad points, minimises the available grip to hold on to and also makes full on braking slightly restricted but there again "white finger" restricts braking power more.
I use the device for everyday use and long trips but took it off when I went on the track day.
I'd recommend their use but check out who else sells them I think mine came from m&p but I cant be sure.
beeman
J Hop
Re: Cramp Buster?
« Reply #2 on: September 06, 2006, 07:52:20 PM »
Good points is that no "white finger" develops after rides.
I've had white finger develop during very long rides (think it is carpal tunnel syndrome). It is not very nice and is probably very dangerous when you cant grip the bars properly.When I got it my hand stayed curled and I couldn't straighten out my fingers, had to stop and shake my hand about for a bit.
Re: Cramp Buster?
« Reply #3 on: September 06, 2006, 09:19:16 PM »
Jethro has one on his sidecar outfit, he seems happy with it.
Re: Cramp Buster?
« Reply #4 on: September 06, 2006, 10:24:42 PM »
Aye Jhop,
'White finger' and 'carpal tunnel' are 2 very different conditions.
'White finger' caused by vibration, over exciting the nerves and small blood capilleries in the hands, causing the capilleries to contract. Hence loss of blood supply, oxygen, warmth and a tingling sensation despite numbness. Use thicker handlebar grips, don't grip so hard (chill man!), heated handlebar grips, loose fitting gloves and a more upright, weight off the forearms stance when riding.
'Carpal tunnel' due to inflamation of the tendon sheaths through which the tendons run, passing through the carpal tunnel in your wrist. A form of repetitive strain syndrome. Lifting heavy weights with your finger tips, multiple trays of bedding plants, stacking lengths of timber ready for extraction after felling by hand rather than using pulp hooks and tongs to grip the timber. Arm fulls of books when re-stacking library shelves.
Being a wood cutter as Smudge will testify, induces both injuries, the only cure for which is rest and abstinance from using chainsaws or any vibrating machinery and lifting or stacking repetitively any heaving objects by hand.
So installing large single cylinder engines into frames using your finger tips and then hanging on whilst riding said motorcycles tends to be an occupational hazard. ;-)
Keep bopping, Bill
