Author Topic: DR Clutch- weekend prebrief!  (Read 606 times)
« on: September 28, 2007, 09:45:10 AM »
Hi all, any advice?
The DR clutch has begin to slip a bit, only with a big handful, but still...
I think its a new clutch about 4000 miles ago, the previous owner (a mate) put it in.  I read the Suzi manual last night, and it looks like pretty straightforward wet multiplate clutch.
Any insight?  Do they have a reputation for being a bit weak?  I've had clutch slip before when using car oil, but but its good bike oil this time...
So I will go and investigate, but suspect maybe a spring has broken, or the plate-retaining bolts have started to unwind.
Must do an oilchange soon as well...!
cheers
Re: DR Clutch- weekend prebrief!
« Reply #1 on: September 28, 2007, 09:52:35 AM »
Andy, the 750 clutch is similiar (uses the same plates I think), fairly standard to work on. Mine was slipping to start with, turned out to be a sticky clutch cable not returning properly. Works fine now after sorting the cable. Worth checking as you tend to get used to a cable slowly getting stiffer and may not have realised how bad it is.
« Reply #2 on: September 28, 2007, 10:04:06 AM »
Thanks steve!
Just the sort of reply I wanted- forums rock!  I'll check this before thaking the cover off.  But it seems ok (from memory!!)
Speak soon
