Author Topic: Exhaust sealant  (Read 868 times)
Exhaust sealant
« on: September 10, 2007, 07:30:17 PM »
I need to resort to some sort of sealant for the joints on my Skorpion's exhaust can anyone recommend one that is flexible and isn't a complete pain in the proverbial when removing?
TIA
Re: Exhaust sealant
« Reply #1 on: September 10, 2007, 08:21:53 PM »
Ive always used silcone bathroon sealant. It was recommended to me by Gazelle in West Wales, after they built a system for me (a long time ago)
Re: Exhaust sealant
« Reply #2 on: September 11, 2007, 04:43:28 PM »
Ta, I have some heat resistant stuff - looks and smells right - I'll try that. When I get around to taking the system off again
Re: Exhaust sealant
« Reply #3 on: September 13, 2007, 01:28:07 PM »
I use this on pipes...  Its ok, doesn't last forever, but will get you thru an MOT (and scrutineering)
No complaints with it tho.
Re: Exhaust sealant
« Reply #4 on: September 14, 2007, 10:17:52 AM »
Holts fire gum, got it off e-bay.
pigafetta
Re: Exhaust sealant
« Reply #5 on: October 01, 2007, 11:34:48 PM »
Will any old silicon sealant do the trick or do you have to specifically use heat resistant stuff? I've got a predator on my XBR and every few months the paste falls out and I have to redo it. Being essentially bone idle, this is not ideal for me and I'm looking for something that'll last a little longer. Is Fire Gum any better than other pastes? I've tried a few with the same results.
Dave
Re: Exhaust sealant
« Reply #6 on: October 02, 2007, 10:13:29 AM »
The stuff I used wasn't specifically heat resistant, but it was "heavy duty".  Took about 24h to go off.  Applies white, goes clear when dry.  Also good for sealing switchgear!!
Give it a bash- at worst it will burn/melt off.  May mark the pipe, but will proabbly polish out/off.  Just dont slather it on too copiously!
OMEGAMAN
Re: Exhaust sealant
« Reply #7 on: October 02, 2007, 04:43:09 PM »
So long as you don't want it to look pretty, I some times use Firegum or suchlike & then wrap the joint with a bit of exhaust bandage followed by locking wire which keeps the gum in place a lot longer!
Failing that!      I just have the whole system welded together & forget about it for a long long time! ;)
