Author Topic: GB carb removal  (Read 588 times)
GB500nz
GB carb removal
« on: June 14, 2007, 08:02:44 AM »
I have to take the carb off the GB, which appears to require a lot of disassembly to get clearance. Has anyone tried removing the forward engine bolts and hingeing the lump forward? That seems a lot easier.
Re: GB carb removal
« Reply #1 on: June 14, 2007, 03:07:01 PM »
I haven't tried that method.
Does your inlet manifold have the removable plate? (some models have a one-piece manifold, some have a two-piece one). I remove the plate and with the airbox and manifold clamps slackened off it (and throttle and choke cables removed) it gives me just enough room to get the carb out.
I did it on the side of an autobahn in the dark once :(
Re: GB carb removal
« Reply #2 on: June 14, 2007, 05:41:37 PM »
I say, try to keep it clean old man! There are youngsters about you know!
Now, what were you saying about carburettors before the smutty outburst??
