Twin carbs with two seperate float chambers Steve?
Not like the old set up with just one float chamber, would this make the difference?
Does the cant on the sidestand make a float (or both) stick on its pivot, so preventing the float needles from seating at the same time?
Is the rubber tip(s) on the float needles ridged or worn, preventing seating?
Is it possible that one carb is partly starved of petrol by the other, because the fuel tap/line isn't of sufficient bore to match the fuel flow requirements of two carbs?
Are the filters in the tank or line chocked?
I hope you can find the cause Steve.
Regards, Bill
