Author Topic: Piston ring question  (Read 745 times)
« on: August 26, 2022, 04:17:31 PM »
Hi all
As I am not sure yet whether the one-way valve in my engine breather on the Mighty Midget will lessen the oil consumption I bought a set of piston rings in case I need to change the barrel. However I'm not sure I will use them.
They are obviously Chinese and the top two compression rings seem identical with no markings on or different profile. The genuine rings have an N or R stamped on the upper face and have different profiles, top ring rounded, 2nd ring angled. The oil control ring rails are different, one is consistent thickness the other has a slight step in one face but no indication of which is the top rail and which is the bottom.
I am now reluctant to use them as if I get them in the wrong way around I might make the problem worse.
Any advice people?
Spartacian
Re: Piston ring question
« Reply #1 on: August 26, 2022, 07:59:56 PM »
Aye Spartacian,
I'd be havering too!
Suspect the step in the oil control ring rails would go to the bottom, but NOT CERTAIN!
Genuine rings, inspite of expense; unless unobtainium, would have been my preferred option.  :-X
Hat and coat exit left!
« Reply #2 on: August 27, 2022, 07:42:43 AM »
Cheers Bill
Firstly I hope the tear is mending and you will soon be out and about.
Thanks for the reply, I think we are of one mind, i.e. don't risk it. I suppose it is my own fault for penny-pinching in the first place. Looking at these rings they just don't look like components I want in my motor.
Spartacian
