Author Topic: Tank sealer  (Read 976 times)
Tank sealer
« on: April 28, 2020, 11:11:50 AM »
Has anyone used a tank sealer, was it any good and if it was, what brand ? ta
Re: Tank sealer
« Reply #1 on: April 28, 2020, 04:31:11 PM »
johnr is your man here and POR15 is the seal kit. Best results are obtained using the full, 3 stage kit, consisting of degreaser, metal prep etch and then sealer. If you look in the recommended services section, there's a thread on it, by SteveL. Best of luck.
Re: Tank sealer
« Reply #2 on: April 28, 2020, 05:14:07 PM »
Yes, it’s good gear indeedy Mr spooky, used it on the recommendation of this very forum. Best o luck 🤞🤞👍
Re: Tank sealer
« Reply #3 on: May 03, 2020, 05:43:33 PM »
couldnt have put it better myself. ive used a few sealers and found por15 to be the best of the ones ive used. as has been said, get the full kit so you can clean and derust/degrease the tank prior to sealing it.
