Author Topic: Tool question  (Read 2715 times)
Tool question
« on: February 07, 2020, 03:36:11 PM »
Yes, I have a question! Do I need a Dremel in my tool collection? I really can't think of anything much I could use one for at present, but I thought I may still need one and you'd be the people/fellow tool addicts to ask  ;D
Re: Tool question
« Reply #1 on: February 07, 2020, 04:40:28 PM »
Aye mthee,
Nowt like a stir, eh?  ;)
Personally, I have two. Lost one,  ::)  bought one at an auction for a £5-00 in a box of tools and then found the old one!  :-X
Use 'Parker' accesories (Lidl's finest), for all sorts of fiddly wee jobs on motorcycles and DIY, with my motors. Sometimes a hand tool is easier and makes a better job than trying to control a burr etc at 15,000 - 30,000 rpm!
I believe the 'copies' are as good as the original and a rummage in your local house clearance auction may provide just the item. The auction might also keep you out of the house and entertained for a few hours!  ;)  Just be careful that the acquisition of "useful" items doesn't become a dangerous habit and you end up with a house and property, like some on 'American Pickers'!  :-X
Re: Tool question
« Reply #2 on: February 07, 2020, 10:57:16 PM »
there a very handy tool to have for all sorts of jobs the bits wear out fast but as bill says use the  lidl,s bits they usually bring out a box of bits now and then for small money  ,,tommy
Re: Tool question
« Reply #3 on: February 08, 2020, 08:18:38 AM »
The thing I use mine for more than anything is cutting off rusted nuts. They're bloody brilliant for that!
Re: Tool question
« Reply #4 on: February 08, 2020, 09:56:42 AM »
DOH🤭🤭... I can’t believe I forgot the dremel. I will go straight to the headmasters office, I will get six of the best. I will try harder next time. 😉🤘
Name withheld to protect the innocent
Re: Tool question
« Reply #5 on: February 08, 2020, 01:20:31 PM »
should my nuts ever get rusty i'll bear it this in mind...  ;D
Re: Tool question
« Reply #6 on: February 08, 2020, 03:09:22 PM »
The other thing I use mine for a lot is cutting control cables both inners and outers. Makes a lovely clean square cut unlike side cutters etc. The only slight problem is that it melts the outer plastic if I'm not careful.
Re: Tool question
« Reply #7 on: February 08, 2020, 10:40:15 PM »
I may go for one of these Dremel copies then. The reviews certainly seem to back up what Bill said!  ;D Thanks also for the Lidl tip.
https://www.ebay.co.uk/itm/302500854379
But, I really should wait for a job that requires one first... ::) Besides which, I've got my eye on this compound vice for my bench drill, in order to make up my indicator housing.
https://www.ebay.co.uk/itm/283604884525
Re: Tool question
« Reply #8 on: February 10, 2020, 07:16:59 PM »
dremels are handy ive got a couplee, but what i find very handy these days is a little black and decker powerfile! super handy, cleeaning, de rusting, paint prep, lots and lots of uses.
Re: Tool question
« Reply #9 on: February 11, 2020, 12:12:40 AM »
That powerfile looks handy! And affordable too  ;D  Like a portable, mini belt sander?
Re: Tool question
« Reply #10 on: February 11, 2020, 01:43:57 AM »
exactly, and its super controlable, i use it absolutely loads now.
Re: Tool question
« Reply #11 on: February 11, 2020, 01:13:51 PM »
I've seen these used on YouTube for profiling seat pans and maybe foam as well, can't remember. I assumed they were expensive for some reason. Also, having cut off the ignition key mounts, I have the aluminium top clamp to reprofile, plus side panel lugs to get rid of. Amazing reviews online and £42 delivered  ;D Many thanks!
Re: Tool question
« Reply #12 on: February 12, 2020, 10:15:21 AM »
Yes, I got one for redoing the seat on my Honda 400. Used together with an electric carving knife (yes, really) it made a decent job of reprofiling the foam. When I find my extension cable I need to use the file to ease the fit of various exterior wooden doors in our "new" house.
Re: Tool question
« Reply #13 on: February 13, 2020, 03:23:20 PM »
The powerfile arrived this morning and I just had a little dabble - wow! It's going to sort my top yolk in no time. I only touched it a few times with the tip of the powerfile which was on it's slowest of 5 settings and watched it do 5 mins worth of  hand filing! I think it came with 3 X 40 grit belts and the lightest you can buy is 125? Big recommendation and thanks to johnr.
