Author Topic: Keihin Carb parts  (Read 3427 times)
Keihin Carb parts
« on: April 25, 2007, 10:36:33 PM »
Hi
I have been searching all over and to no avail - I cannot find out what should be on the end of the air / fuel screw on the CG - it is a Keihin PD88 carb and I have one really poor pic that suggests that there is an O ring (no prob) and a bush or a washer - no probs if I have the dimensions etc.  But I cannot find owt and the Boss is demanding that I swithch this thing off.
Anyone help please?
Re: Keihin Carb parts
« Reply #1 on: April 26, 2007, 08:18:10 AM »
I've got a pair of CG carbs in the garage, I'll wander down there tonight and have a gander.
« Reply #2 on: April 26, 2007, 11:05:32 AM »
Ta muchly GC - take care though they seem to stick in the bore of the fuel/air screw and then fall out when least expected into the leaf mould never to be seen again.
« Reply #3 on: April 26, 2007, 12:17:53 PM »
My garage may be cluttered, but it doesn't have leaf mould on the floor :)
pigafetta
« Reply #4 on: April 26, 2007, 12:21:43 PM »
I've never had a CG, but CDs and CBs have an O ring on the air screw and a spring behind it. Could be the spring your missing. i'm just guessing though.
Dave b
« Reply #5 on: April 26, 2007, 01:21:18 PM »
Yup there is a spring and an O ring - but also something else - a washer or a bush between the spring and the O ring.  I can see it on a poor drawing I have (Haynes) and I have seen on the interweb.  In Haynes they are both called "O ring" Ummmmm
I did think I was imagining things and put mine back together with out - the spring chewed the O ring into bits - guessing the other bit is to avoid this.
ken
« Reply #6 on: April 26, 2007, 06:51:31 PM »
Just had a look on my  manaul for my Dommi. It shows the screew the spring a washer and an O ring. I would guess the washer is a fiber washer.
« Reply #7 on: April 26, 2007, 10:27:55 PM »
The Washer is a little steel number.
To stop the spring mashing the O-ring.
« Reply #8 on: April 27, 2007, 11:06:06 AM »
Experiential learning tells me that - is it just a lil washer with the similar ID and OD to the O ring - or is it thicker than a 'normal' washer?
« Reply #9 on: April 27, 2007, 04:26:32 PM »
Experiential learning tells me that - is it just a lil washer with the similar ID and OD to the O ring .......
YES !
« Reply #10 on: April 27, 2007, 04:38:28 PM »
Thanks - will see what I can do tomorrow with two boys in tow.
