Author Topic: Enfield final drive chain issue  (Read 4540 times)
« on: February 23, 2019, 04:05:44 PM »
Further to previous posts regarding swapping out junk Enfield o ring chain to non o ring type, I tried out my new oiler today in the bonus February weather.
Result is good.
Re: Enfield final drive chain issue
« Reply #1 on: February 23, 2019, 04:20:34 PM »
Are you sure that's oil in that hip flask?
Be interested to know how you get on as I now need my fourth chain at 20000 miles. Oh and my third set of sprockets!
« Reply #2 on: February 23, 2019, 04:41:36 PM »
Yes Ian, I keep my whisky in another one on the right hand side ha ha.
I'll keep you updated.
« Reply #3 on: February 23, 2019, 04:46:38 PM »
Bit of an arty farty shot showing the glorious view over the reservoir. Oh and my hand carved ally parts 😁
« Reply #4 on: February 23, 2019, 11:24:46 PM »
Great shot and great work. Got any more pics? :P
« Reply #5 on: February 24, 2019, 08:22:16 AM »
Thanks 👍. It was a great way to kick off this year's riding. Threading my way around the tiny roads linking fewston, swinsty and thurcross reservoirs. Fair bit of dry salt knocking around but I gave Norman a good wash 😯😁. All the winter mods work well especially the functioning of the hip flask and a more hidden mod which ditches a pathetic intake snout at the back of the right-hand box (the air filter box). The surface area of the snout was pathetically small, probably a noise reduction thing. It has gone now and I have an ally plate covering the general area to stop muck getting in but it "fills out" the sound and seems to allow the motor to rev a bit more freely. It ran better than it has done since I've had it.
Another shot.
« Reply #6 on: February 24, 2019, 08:26:41 AM »
Don't know how to download multiple shots so here's another, showing of the lovely sunshine 😁😂
« Reply #7 on: February 24, 2019, 10:48:17 AM »
If ever I go to buy an Enfield, your model is looking favourite! Although, here's one that was on fleabay I kind of liked after watching Easy Rider - before and after pics;
« Reply #8 on: February 24, 2019, 05:07:01 PM »
Great shots Andy and a lovely looking ride.
I have to say I love my Enfield but it really is a turd that I have to keep polishing. Today I discovered that despite constant lubrication and adjustment there are 6 teeth missing on my rear sprocket! I am a little fed up with the poor quality of components on the Mighty Bullet but as I can't afford the silly prices people want for motorbikes these days I am stuck with it. Now where's my turd polish!
« Reply #9 on: February 24, 2019, 09:13:29 PM »
Cheers Matt.
Sorry to hear of your woes Ian.
This is possibly not related to your exact issue but worth a mention. As part of my modifications to the mounting and rotating the mudguard I removed the shocks and jacked up the rear wheel to simulate bottoming of the suspension, to ensure the tyre clearance was ok. What I noted was how tight the chain gets at this position, in spite of having decent slack set into it on the sidestand. I believe that the swingarm on my model is a bit longer than on yours so it is possible that the phenomenon is more pronounced with your bike....?
« Reply #10 on: February 25, 2019, 07:23:04 AM »
"Showing the lovely sunshine " mmm..... I noticed how Norman still get his rear end in there tho. Ooo eerr vicar 🤣🤣🤘
« Reply #11 on: February 26, 2019, 05:19:36 AM »
Cheers Matt.
Thanks Andy it's a thought and worth checking. I have decided to convert to a bolt on rear sprocket. Hitchcocks sell a conversion rear hub with the teeth machined off and then you can buy a bolt on sprocket made by Talon. These should be much better quality than the Indian ones. However the bolt on hub is £96, but as I have a spare with missing teeth, a friend with 40 years engineering experience and access to a fully equipped machine shop I won't be paying that!
« Reply #12 on: February 26, 2019, 06:07:08 AM »
My model has a separate rear sprocket, mounted the way a typical jap bike is. Different swingarm too.
« Reply #13 on: February 26, 2019, 07:31:03 AM »
Oh you lucky man Ian.... one can dream 😉👍. Best o luck with the sprocket conversion.
« Reply #14 on: February 26, 2019, 11:22:23 AM »
I second that emotion and it's not coming from a welding/cutting/forming genius, it's coming from the bottom of the meccano end of the technical ability chain, i.e. drill (no pillar)  :'(
