Author Topic: Any mancave / shed Experts Out There?  (Read 2440 times)
« on: February 08, 2018, 06:51:06 PM »
We have recently moved house so i lost my lovely insulated timber workshop in the back garden. Part of the deal with the wife was that i would be "allowed" to have a lean to on the side of the single brick garage in part of the rear garden. Our builder who has spent the last 5 months updating the bungalow is about to start work on the rear garden / lean to. It's going to be insulated timber again but necessarily much smaller in size.I will have quite a bit of overflow space in the loft for parts and dismantled projects but will have to keep most of my bikes in the lean to.I should be able to work on the bikes in the back garden or the garage but can't use the garage to store the bikes as we have a sports car that MUST (for insurance purposes) be in a locked garage at night.Any tips on the best construction for the lean to would be greatly appreciated.
Re: Any mancave / shed Experts Out There?
« Reply #1 on: February 08, 2018, 08:53:05 PM »
I built a detached man cave, took me about 18 months, but I did do it all myself, (will post you a couple of pics later), basically I put 1m concrete into a 2m trench, then thermalite block up to damp course, then 6 course of brick with 2m posts at 1m space let in to the brickwork, same posts used for top horizontals using galvanised 'L' brackets on each upright/horizontal junction, every 3m I put in an angled brace between bottom of one post to top of adjacent post. put in spaces for windows and doors as I went. (made the windows myself, got the doors from local recycle center). then fitted the roof trusses, felted and battened (battens spaced for second hand Norfolk pantiles), I then used same felt on the outside of the wood post uprights bottom 6" I put 'flashband' 3" up the post & 3" over the brick base, then the bottom run of felt overlaps the flashband. then nailed up 7" feather edge board (in black), once outside weatherproof, I fitted celotex board between the uprights (I ordered enough to insulate the ceiling as well), then finished the inside with mdf boarding, and the ceiling with plasterboard. (before the celotex went in, I put in the wiring for lights / switches / sockets etc)
I used plastic fascia and soffit in black, (not ideal, but maintenance free). got most of my new stuff from Jewsons (mates son is manager, so managed to get 'mates rates') trusses made locally , and plastic stuff I got via the internet., oh, the floor... .thought long and hard about that.... concrete too expensive, suspended wooden floor too posh and too expensive.... opted to level off soil inside, then got a thumper to compact it, then laid an inch of soft sand, then put in 2 layers of plastic dpc, then laid 30 top quality second hand pallets (must all be the same size), then put in a double layer of stirling board.... been in 6 months now, got 4 bikes at one end , 2 heavy work benches and lathe at the other, and all seems good and stable, floor creaks nicely .... good luck with your project...
« Reply #2 on: February 11, 2018, 09:05:04 AM »
Interesting Steve....my knowledge and abilities of building are extremely limited to say the least.......but the builder came yesterday and together with Wifey we sketched out a rough plan. Looks like i shall have enough space for at least 2 full bikes with storage at the back of the garage which will form an L shape for the lean to.Access will be quite tight into the building as there isn't much of a turning circle.Construction is still under discussion but the base is going to be concrete......
« Reply #3 on: February 11, 2018, 11:00:01 AM »
Don`t forget to sink a ground anchor into the concrete for securing, it all helps,  and a wide door !!
« Reply #4 on: February 11, 2018, 04:29:49 PM »
Yes-good point ;D.Going to alarm it as well.
