Author Topic: Supercharging!!!!!  (Read 13914 times)
Supercharging!!!!!
« on: February 26, 2017, 10:18:00 PM »
With a query from LoCo about modifying an XT in the 'Technical' board and the ongoing posts from Joolz and Ellwood, I thought this site might interest and give food for thought too others!  :)
Elsberg-tuning_dk
If you are interested in V8's, then have a wee look on the site in the "Cars" section!  ;D ;D ;D
Re: Supercharging!!!!!
« Reply #1 on: February 26, 2017, 10:24:15 PM »
And this is just pure 'Thumper' pawn!!!!!  ;D ;D ;D 8)
Falcone_Compressore_500cc
Bill
« Reply #2 on: February 26, 2017, 10:59:18 PM »
Bloomin heck Bill! And by pure coincidence, I've just adv my Nuovo Falcone on Done deal tonight   ;)
« Reply #3 on: February 27, 2017, 10:43:32 AM »
Some good stuff there :)
« Reply #4 on: February 27, 2017, 12:07:44 PM »
Thanks, Bill, I found it very interesting as I had no idea how a supercharger worked. But even so, I'd never have thought they'd be found on small engines. To think, I could've had one on my SS50 and maybe seen off Michael's SS80!
Google reveals one for the shallow of pocket/diy fans;
http://www.ebay.co.uk/itm/ELECTRIC-TURBO-SUPERCHARGER-KIT-UNIVERSAL-FIT-For-Motorcycle-/252716403280?hash=item3ad7124a50:g:jzQAAOSwLnBX2SEB
And one for those who prefer it to come incorporated into a complete package from the factory. Lots of description here on how this supercharger works on the bike which has
specially adapted inner wheel rim surfaces to counter tyre creep under extreme acceleration! Might use the ol' full face on this one!
http://www.motorcyclenews.com/bike-reviews/kawasaki/ninja-h2r/2015/
« Last Edit: February 27, 2017, 02:37:37 PM by mthee »
« Reply #5 on: February 27, 2017, 06:50:37 PM »
i think that vw have whats possibly the cleverest system. superchargers deliver boost from tickover, but sap power, or to be precise, they use engine power to provide boost, turbos use essentially wasted power to provide boost by utilising the exhausted gas, however turbos normally can be a struggle to get power from at low revs, and if you get one that delivers at low engine speeds, then its too small to be much good at high engine speeds, and visa-versa. the vw system has a supercharger that is driven by the engine at low speed, but it has an electronic centrifugal clutch built in so that when engine speed rises above a certain level it disengages and as such doesnt sap any engine power, at the same time, the turbo is spinning away in the exhaust and as soon as there is enough boost then it is utilised to provide the engine with boost. effectively its the best of both worlds, supercharger grunt and turbo power. i imagine its a plumbers nightmare of pipes and wires that are best hidden under a bonnet.
« Reply #6 on: February 27, 2017, 08:59:19 PM »
Blimey can't believe I've been mentioned in the last two posts "a plumbers nightmare" ah that all depends on how good the "plumber" is 😉😉🚽🛁🔧......and secondly "blow off Michael's SS80" .......not a chance Matt, 😉😉😉😁 used to blow off fizzies that thing. Brilliant at 16years old I gotta say. Cheers, Michael
« Reply #8 on: February 28, 2017, 10:24:56 AM »
In reply to mthee's post, dont even think about buying one of those electric superchargers from ebay, they are totally useless on any size engine, they are pretty close to being fraudulant. I have only seen one company that make an electric supercharger that works, and that had 3 starter mortor size electric motors to run it, even then it was only to be used as an occasional boost as the battery would run down after about 30 seconds.
There are only 2 options, drive it from the engine or drive it from the exhaust
« Reply #9 on: February 28, 2017, 11:05:01 AM »
My favourite bit on that ad is their disclaimer;
"We take no responsibility in teaching you how to install. Professional installation is strongly recommended."
Yeah, right! If you can get the professional installer to stop laughing for long enough! Unless the professional installer has a really warped sense of humour, in which case he might just install it for you :o
« Last Edit: February 28, 2017, 11:09:38 AM by mthee »
« Reply #10 on: February 28, 2017, 08:22:23 PM »
This is a 1940's idea
The hump in the bottom of the Lancaster derivative contains a fifth Rolls Royce Merlin. This drives a roots blower of large proportions, whose output is directed into the carburettors of another 4 on the wings. A true plumbers nightmare, fortunately  overtaken by common sense and the jet age.
https://en.m.wikipedia.org/wiki/Avro_684
Maybe try a C90 motor blowing your XBR?
« Last Edit: February 28, 2017, 08:29:27 PM by Andy M »
« Reply #11 on: February 28, 2017, 08:30:54 PM »
Wow! That really puts it all into perspective!
I'm off to see if I've sufficient cable ties to mount the C90 engine...
« Reply #12 on: February 28, 2017, 10:56:30 PM »
i thought that the spitfire merlin engines had a supercharger on them anyway?
« Reply #13 on: March 01, 2017, 07:01:19 AM »
Stepped piston?
Then there's the guy who turned his Ducati rear cylinder into a compressor. I applaud him, although I can't help thinking that the rear piston would be put to better use with explosions going on above it.  ;D
« Reply #14 on: March 01, 2017, 08:10:48 PM »
They did.
Aircraft superchargers were about getting low altitude power at high altitude. The slave engine had a supercharger as well as driving one. The big blower fed air into the others as though at 20000 feet at 40000. The result is an aircraft with enough power to go to 50000 feet instead of running out of power at 22000.
