Author Topic: W650 or V7 to replace XBR?  (Read 29129 times)
Re: W650 or V7 to replace XBR?
« Reply #30 on: February 14, 2017, 02:07:18 PM »
is the w650 in post above the actual bike you are looking at ?   it`s really nice,   get it...
« Reply #31 on: February 14, 2017, 02:27:54 PM »
Isn't it! It's this one;
http://www.ebay.co.uk/itm/Kawasaki-W650-UP-EJ650-PERFECT-EXAMPLE-/232233741284?hash=item361235abe4:g:TNIAAOSwA3dYm4Fg
Too far to test ride, I'm afraid. Anyway, I'm off to abuse the XBR and see what happens - probably tomorrow. :D
« Reply #32 on: February 14, 2017, 03:42:36 PM »
Matt, I'm not to far from Preston (approx 30 mins down M65 motorway) so if you do come up norf to purchase the kwak it'd be good to meet up and possibly sneak a swift beer in🍺🍺..cheers, Michael
« Reply #33 on: February 14, 2017, 08:15:33 PM »
Cheers, Michael, that'd be awesome. Now that I've been looking at that W650 on eBay, the advertisement banner on this site has picked it up to torture me with. I'm looking at it as I type! :P
Rossco500
« Reply #34 on: February 16, 2017, 12:05:44 AM »
Just thought I'd post my thoughts on the W650 that I'd previously PM'd to Matt - Sorry if I prattle on a bit!
As Tim mentioned I've owned 3 w650s (first one crashed and replaced with another), a w800, a 2010 Triumph Bonneville T100 and numerous XBRs. I've probably clocked up about 35k miles on the w650s so I know some of their plus and minus points. Xbally has hit the nail on the head with his comments although I'd suggest they are a bit more torquey as a long stroke twin given their lowish capacity (in modern terms anyway!). The handling is much improved with lower handlebars and decent tyres although they can still become a little skittish approaching 80mph-ish. I suppose performance depends on the sort of bikes you have owned up to now - I find them quite lively (not having had any sports bikes or the likes!!) although you'll probably still have to drop a gear for any hairy overtaking manoeuvres. Realistically though I'm not sure how much quicker you'd find them over a well set up xbr.
If you can Matt, I'd definitely recommend getting a longish test ride to see if you like it. The Bonneville is quicker and better handling at higher speeds, but after a few niggly build quality and FI related starting issues I didn't really warm to mine - as I said, just not for me and I certainly don't want put anyone off the Bonnie - many will prefer them. The new range of models does appeal though. I've also had one of the first of W800s which was ok too - heavier than the w650 (mostly down to all the emissions kit in the exhausts?) - performance was broadly similar to the older model but more torquey at lower revs and just as, if not more economical. Unfortunately it just sounded so quiet ( Lol!) and I was aware of some problems with the throttle bodies and didn't want to get caught with a major expense out of warranty. I understand that these are eventually being sorted / replaced some years after the problem was highlighted by owners.
One thing I would say is that if you do get a w650 and find that its not for you should at least get your money back or possibly make a few quid. Its a pity you aren't able to hold onto your XBR as you'll probably regret selling it!
They can get a bit buzzy through the bars and pegs around 65mph but is ok below and above that. You may not even notice it and it varies from bike to bike. Some folks fiddle with the airbox and jetting but unless you know what you are doing this is maybe best avoided. However I have read that if done correctly in combination with some less restrictive pipes there can be small gains in horsepower (Check the John Haddock mods). Its quite easy to drill out the baffles for a much deeper note though they aren't bad with the standard pipes.
The engine seems to be quite a tough unit as evidenced in the old ebay link below. There have been isolated cases of teeth shearing in the bevel drive but this is rare.
The early models (A1) were all light blue/silver or maroon/cream with high bars and were made from 99-01. Post 01 bikes came with lower bars, some minor changes to improve handling and a more comfortable ribbed seat. They also came in a different range of colours and are probably the ones to go for.
Plus points -
They are a fun bike which is slightly different from most other stuff out there.
Easy, cheap to owner maintain and not hard on consumables.
Can be very economical 60 - 70 mpg fairly typical. I tended to get slightly over 50mpg from the Bonneville ridden at the same speeds
Fitted with centrestand, grab-rails, bungee hook points, toolkit etc as standard.
Watch out for -
Imports - not necessarily a problem but some of them aren't fitted with the carb heaters to prevent icing. Some of the Jap imports on sale at the moment may fall into this category. If they are European Imports they may be fitted with MPH clock overlays (look out for the word "Redial" at the very bottom of the speedo face).
Handling not too bad but can skittish as mentioned above - fit progressive fork springs / Hagons or similar shocks.
I have experienced carb-icing on one of my bikes in certain conditions but not on the bike I own at present. Not uncommon on some Kawasakis of that era.
They aren't overly quick but I suppose most folks going for this type of bike are well aware of that.
The youngest of them is now 12 years old.
I'd recommend having a look at these websites / forums :- ADVRIDER (W650 - under "new to me"), The Lonely Ones and w650shop.de. Also check out John Moulton's review of his own w650 in the Real Classic website.
And have a look at this 100,000+ mile example sold years back on EBAY. Scroll to the bottom of the link for his description:-
http://www.ebay.co.uk/itm/150589903734
Hope this information is useful but as I said Matt its worth taking a test ride to see if you like it or not
PHEW!!!!!!!!!!!!!!!!!!!!!
All the best
Tony
« Reply #35 on: February 17, 2017, 05:07:20 PM »
Take it out somewhere quiet and give it a thrash over 6k in 3rd & 4th and see what you think you may be surprised ( 5th is basically an overdrive - it is probably faster in 4th flat out than 5th but not a good idea to thrash it that much!)
Aaaaah, I see, Steve! Bit of a revelation to me, really. Only just back from a 25 miler, my first since discovering I had a windfall coming, during which I took your advice and pretty much didn't use 5th. The sound of the motad howling at 6-7 1/2k! No gushing oil leaks, phew! I was worried the slight weep from the cylinder cover bolt might reappear when thrashed, but it didn't 😓
I guess my desire for a W650 has been (partly) extinguished - it's never going to sound as good, or be quite such a good fit, given how small we both are! The money can go in the bank and on some new gear without my feeling guilty.
I know I'll have a W650 as well as, not instead of, one day. My thanks to everyone who contributed, especially Steve & Tony.
« Last Edit: February 18, 2017, 10:40:25 AM by mthee »
« Reply #36 on: February 18, 2017, 10:44:46 AM »
Matt,i think you may have made the right decision!Since i sold my last XBR i've missed it quite a bit.Thanks to Moto63 i am soon going to be back in the fold.I would see if you can save up for the W650 ,but certainly take a test ride and DON'T SELL THE XRB-as others have said-you'll regret it!
Martin ;D
« Reply #37 on: February 18, 2017, 10:53:50 AM »
Thanks, Martin. I really feel this windfall instantly put me in a bike-buying frenzy in which all logical thought abated -  I HAD to get a different bike. Lucky for me, the wiser heads on here pulled me back and I (eventually) saw sense.
« Reply #38 on: February 18, 2017, 10:57:54 AM »
A lot of folk seem to think that because it's a big single it's an old plodder like the old Brit stuff but it isn't, it's based on the XR500 desert racer and goes pretty well when you give it a bit of throttle ( for a 500 single).  I think you probably made the right decision in not selling it Matt, but you can always save up for the W650 as well...it is a very nice looking bike.
« Reply #39 on: February 18, 2017, 12:31:47 PM »
In my case i wouldn't say i was wiser-just have a lot of experience chopping and changing bikes........it's very easy to get carried away when you have some money burning a hole in your pocket....don't ask me how i know!
« Reply #40 on: February 18, 2017, 03:20:23 PM »
Ahem.......
« Reply #41 on: February 18, 2017, 04:13:06 PM »
not that im ever going to be accused of recomending one, but i suppose the residuals on the sportster will be better if you decide to sell it on, but as has been said, you have to cope with the hog bores whenever you park up, and reliability can be an issue with them, mate of mine spent years saving to buy a sportster, and loved it, but it was fantastically unreliable in the way that only a chinese design assembled in russia by chimpanzees on crack could match.....
« Reply #42 on: February 18, 2017, 04:23:40 PM »
.. chinese design assembled in russia by chimpanzees on crack could match.....
I've had BMW's.  :(
« Reply #43 on: February 18, 2017, 04:55:06 PM »
Ahem.......
Ok, Ok ... not all Brit singles :-[.....I was meaning more the sidecar pullers and go to work plodders etc.... I'm sure you know what I had in mind.
Rossco500
« Reply #44 on: February 24, 2017, 10:27:00 PM »
Hi Matt - sent you a PM
Regards
Tony
