Author Topic: should i sell ?  (Read 3794 times)
Re: should i sell ?
« Reply #15 on: November 26, 2016, 04:43:43 PM »
IIRC the idea was so that the disc worked in the wet. Those with long riding experience will remember the experience - you pull the lever gently - nothing happens - pull it a bit harder - still nothing - then as your knuckles whiten the water eventually gets wiped off and the front wheel locks.......
Re: should i sell ?
« Reply #16 on: November 26, 2016, 07:56:09 PM »
I had a CBX550 about three years ago, nice enough bike but pretty gutless and the enclosed, vented front discs were a nightmare. It used to wobble when slowing down from about 30mph if you took one hand of the bars? Apparently  they did this but don`t know why? Don`t know why they even enclosed the discs?? Would I have another? ..... probably not.  :-\
PS. Sanglas is nice but I think fate has dealt you the right hand Rufus, HD for me  ;)
« Last Edit: November 26, 2016, 07:58:30 PM by manxie »
Re: should i sell ?
« Reply #17 on: December 01, 2016, 09:09:44 PM »
Still haven`t been to see the local Sanglas, however i have found one in spain that is half the price and i can get it shipped home for £450, something to think about and this one has a drum front brake, so... do i want to sell my ss350 ?   :-\
Re: should i sell ?
« Reply #18 on: December 01, 2016, 10:53:14 PM »
NO!
Re: should i sell ?
« Reply #19 on: December 01, 2016, 11:27:40 PM »
  Ha, that`s told me !      i will think about it, it`s cos it`s winter and the ss350 is hidden away..
Re: should i sell ?
« Reply #20 on: December 01, 2016, 11:32:04 PM »
I'm with Bill. Don't do it Rufus! But then, I don't even listen to my own advice  ;)
Re: should i sell ?
« Reply #21 on: December 03, 2016, 10:18:00 AM »
I still haven`t been to see the sanglas in Newcastle, but a friend has and he says it is a bit of a dog, ripped seat, bigpool of oil, generally well overpriced,  however i am still dithering over the spanish one... but i would have to sell my HD, not much chance of that this time of year methinks,    :-\
Re: should i sell ?
« Reply #22 on: December 03, 2016, 05:57:09 PM »
how do you know that the one in spain isnt an equally rabid dog but just further away, and with the disadvantage that by the time you actually get to see it, then its too late cos youve paid and the seller has pretty much had plenty of time to sell it.
as for inboard disks, they were a solution to a problem that neednt have existed but for vanity.
bike disks live out in the open air and so corrode, but manufacturers dont want people to see their product with rusty bits exposed to view. so, in the 1970s when disks were becoming the norm for all bikes, they experimented with stainless steel and chrome plated disks. they looked great, they didnt rust, problem solved but for one tiny issue, they didnt work (chrome) and they didnt work in the rain (chrome and stainless) many bikes had chromed disks, iirc triumph and honda used them, most owners hated them till the chrome wore off by which time they were passable. bmw used stainless which were poor in the dry and awful to the extent of being dangerous in the wet. solution was to drill vent holes in the disks, thus allowing the pads to scrub the water away and grip the disk cos of the edges of the holes. they were still bad, but they werent quite as bad. (although the stainless disks would then crack between the holes due to stainless steel becoming more brittle when it got hot and the expansion due to brake heat meant that most drilled beemer disks either have cracks or will have cracks soon.
meanwhile over in italy they didnt really care about a light dusting of oxide, so they fitted cast iron disks to their bikes and they would stand on their nose wet or dry. soon enough metalurgy caught up and steel disks were formulated that wouldnt rust as readily as iron but werent entirely stainless. meanwhile the onboard ventilated disk was invented, oddly it used an iron disk which would have been fine out in the rain, but stuck inside the wheel the heat build up meant that many would crack in use and need replacing.
some wags in the bike press contended that the onboard ventilated disk was hondas way of recouping all the man hours its dealers lost fixing camchains in their v4's by adding another hour or 2 to every service due to the time it took to strip the brakes to check them.
personally, having a bsa in the shed, im well aware of the true meaning of crap brakes!
