Author Topic: What did you do with your bike today?  (Read 89324 times)
Re: What did you do with your bike today?
« Reply #120 on: July 02, 2016, 01:18:25 PM »
Aye Tim,
Just in from spannering, looking for 'bits'! A Yamaha part number cross-referencer for older singles would be nice! And mono singles even nicer  ;)  I suspect XJ600N Diversions and FZR's are going to be the likely stablemates if there is any commonality between models.
Yes, the journey down the A9 was eventful.
The 'barn door' fittings, whilst bolted to the frame have also been tack welded on the back for security!  ::)  So I need to invest in some headlight mounts afore getting the angle grinder out.
Slainte, Bill
« Reply #121 on: July 22, 2016, 10:50:30 PM »
Quick update here!
Out on 'Morini the Minx' with the 'Boy Bros' for a quick hurl through the Perthshire countryside and up onto the Sidlaws for some raspberry picking from the hedgerows. Came back with 5lbs of berries, including some lovely yellow rasps (sweet, different flavour and tasty). Making progress with 'Gert' the SRX400 3VN, with XT600E motor; new front indicators, headlamp mounts, re-wiring headlamp and indicators, awaiting seals to come for between the caliper halves. Four new stainless pistons and seals required for the front caliper (£112 inc VAT  ??? ) plus a pair of stainless pistons and seals for the rear caliper (£55 inc VAT  ??? ) and 'Sally' was given a quick once over. Duke 450 head needing shimmed, will wait until the local "trades" holiday is over and then go and see the engineers with a surface grinder! Car requires service afore MoT next week, lawn mower air filter cleaned, plug cleaned, gapped and blade sharpened.
There was gardening, eating, washing up and tap dancing on this keyboard as well!  ::)
Keep running the beasties, Bill
« Reply #122 on: July 27, 2016, 10:32:10 AM »
Moved the SR and the Bonnie out of the garage whilst I did some carpentry for the new kitchen......put them under covers....then wheeled them back in after job completed.
Thats about as much as I have touched the bikes this week....damn weather
1 BMW C400X
« Reply #123 on: July 27, 2016, 08:27:40 PM »
Took delivery of the new bike ... Jawa 350 TS ... to say it has patina in an understatement  :o No room in the garage for it so it`s under a tarp in the back garden  ??? Some one made me an offer on the Skorp, which is very tempting, don`t know what to do with it, keep or sell but I`m desperate for room  ???  :-\ :-\
« Reply #124 on: July 27, 2016, 09:07:30 PM »
adjusted the chain on the ss350, rode it, puzzled over why there is a wire running through the engine breather pipe ?
got my latest toy delivered, a black russian...
« Reply #125 on: July 27, 2016, 10:13:59 PM »
Congratulations Comrade!! Another Voskhod hits the road! Together we will be able to compare rebuilds, pollute the countryside, tell tales of glorious breakdowns,  excitings rides, terrifying brakes and stained underware!!..........ah the gloriious Voskhod revolution is almost upon us...................all together now................................................."Soiuz nerushimyj respublik svobodnykh, Splotila naveki.......
Photos?
« Last Edit: July 27, 2016, 10:27:44 PM by SteveC#222 »
« Reply #126 on: July 27, 2016, 10:31:52 PM »
Yes, I am looking forward to the forthcoming tales of soviet daring do. I might even sort Minnie the Minsk out  :-\
« Reply #127 on: July 28, 2016, 09:35:41 AM »
I hope you like the Jawa Manxie. They are an acquired taste, but I really like them. The build quality of the cold war era machines is not on a par with MZ's though. There's nothing wrong with the design, but the build quality was a bit hit and miss, and I think they suffered from sub standard raw materials even more than the East Germans.
When they work though, I find them to be quirky, charismatic machines, and fun to ride.
I keep looking longingly at the new Jawa's on the F2 website.......
« Reply #128 on: July 28, 2016, 05:26:32 PM »
Yeah, I`ve never owned a Jawa but just fancied something different and was offered this. Sadly, it`s not an early one. It`s a 350 TS 1992 .... ugly, rough, but sounds ok  :-\
« Reply #129 on: July 28, 2016, 05:28:24 PM »
Jawas are the only bikes i have ever bought new, a 350 twin in 1973 and a 250 single in 1981, i like them, especially the clutch you utilise through the gear lever..
« Reply #130 on: July 28, 2016, 06:06:43 PM »
You sound like the man to ask...? The front brake lever has two cables, one going to the TLS front brake, the other goes to a mechanism which is connected to the rear brake. You pull on the front brake expecting the mechanism to move the rear also (but it doesn`t) You operate the rear brake, the mechanism moves but appears to push against the secondary front cable but doesn`t do anything.....if this all makes sense  ??? ??? What do you think should be happening ?
« Reply #131 on: July 28, 2016, 09:09:41 PM »
Aye Steve,
Never seen or used one but; linked brakes via the rear brake pedal?  :-\  Bit counter intuitive, but all the makes sense through the fug of 2/ and your description.   :-X
Regards, Bill
« Reply #132 on: July 28, 2016, 09:24:48 PM »
Hey Bill,
I was thinking along those lines but if each brake is operated individually, there`s no movement in the other? ie. if I press the rear brake, there`s no movement to the front, and vice verser?  ??? Dunno???
« Reply #133 on: July 28, 2016, 10:10:11 PM »
Sounds weird! any chance of photos?
Is it a factory thing or possibly some sort of adaptation for disability or injury?
« Reply #134 on: July 29, 2016, 07:34:30 AM »
was it ever fitted with a sidecar ?  maybe some sort of parking brake system that has been partially disabled..
