Author Topic: Precision Engineering  (Read 7245 times)
« on: March 25, 2016, 07:23:03 PM »
Well, id tried everything else i could think of  :-\ And this actually worked  :)
Id bought three Smiths speedos from an add in RC, and all three turned out to have problems. One, a brand new 80mph one, had seized up completely, probably due to never being used. All three now working due to WD40 and carefull manipulation.
Re: Precision Engineering
« Reply #1 on: March 25, 2016, 07:47:45 PM »
What you can`t see in the picture is the 3ft bar on your stilli`s for extra leverage  ;D Great job, finger looks nasty  :(
« Reply #2 on: March 25, 2016, 08:13:31 PM »
Funny thing is, I was given that large stilson years ago, and have never found any use for it. Yes, Alison and the three large dogs are hanging off the end of a six foot length of s scaffold pole  ???
« Reply #3 on: March 26, 2016, 11:44:15 AM »
Have a look at Dennis Quinlan's web site. Dennis is an Aussie Velo enthusiast and spent his working life fettling chronometrics.
http://velobanjogent.blogspot.co.uk/2011/12/removal-of-smiths-chronometric-speedo.html
One of his tips, which I used successfully, was to heat up the bezel till you can see the O ring melting and bubbling. It will then easily screw off. It's also better to hold the body with a specially made jig locating on the mounting studs rather than holding the body in the vice.
I too have a pair of Stillsons like that but they're generally reserved for the Discovery......
« Reply #4 on: March 26, 2016, 11:57:20 AM »
Eh up Tim , that finger in the photo looks like it was meant to be inserted in to one of those throbbing things that were mentioned in an earlier post ;) ;) 8) 8)....hopefully on the road to recovery?
« Reply #5 on: March 26, 2016, 01:07:41 PM »
A mere flesh wound Michael, I'm embarrassed to even mention it, in respect of your own injuries. Plus it was pure laziness and stupidity what caused it  :-\
Thanks for the advice Ian. That's what any sensible person would do, but I was on a role and slightly manic at the time. It worked anyway. Will check out the link, thanks for posting.
« Reply #6 on: March 26, 2016, 01:17:44 PM »
Just read the link. I had already tried two different strap wrenches, a chain wrench, and a pair of water pump pliers. I certainly wasn't going to apply a blow torch to a speedo that was in near mint condition  ;)
« Last Edit: March 26, 2016, 08:16:16 PM by timbo »
« Reply #7 on: March 26, 2016, 02:13:32 PM »
But surely applying the stillsons hasn't done the bezel any favours?
When I did it nothing was damaged at all (other than the O ring). I used one of those cheap pencil type gas torches.
« Reply #8 on: March 26, 2016, 07:37:50 PM »
There's a couple of minor marks, and i applied very little pressure, so its ok. What could possibly go wrong  ;)
« Reply #9 on: March 26, 2016, 08:16:22 PM »
Crackin job, they look great .... I love these old clocks, I think they`re a work of art in themselves  8)
« Reply #10 on: March 26, 2016, 09:07:55 PM »
Aye, just need to test them on my mates 350 Matchless, then one of the 120mph ones will go onto a G9 Matchless twin, and the others sold on. Well, that's the plan  ;)
« Reply #11 on: March 26, 2016, 09:24:32 PM »
Did you have any bits left over? :o
« Reply #12 on: March 26, 2016, 09:40:04 PM »
I would have, I'm sure, if I'd stripped them. They look well fiddly  :-\
No, I only unscrewed bezels, and removed inner complete from case. Working on the KISS principle  ;)
« Reply #13 on: March 27, 2016, 10:03:34 AM »
They're fascinating things to work on but as you say fiddly. The trip wasn't working on one I stripped and when I foolishly took it apart bits went everywhere. Eventually I worked out how it was supposed to work (devilishly complicated) and got it back together but I wouldn't want to do it again. My fingers are too big & clumsy not to mention ageing eyes.....
