Author Topic: Small Batteries  (Read 2517 times)
guest1406
Small Batteries
« on: May 24, 2015, 09:26:00 PM »
Hi all,
Coming near to the electrics of the bike and need to think of battery box and battery. Whats the smallest or just small batteries around? I know the antigravity ones are teenie weenie but they have to be shipped and are £70ish. I dont mind them being a bit bigger.
Bike is a Suzuki GN250
Cheers Guys,
Mackenzie
Re: Small Batteries
« Reply #1 on: May 24, 2015, 10:28:54 PM »
Aye Mackenzie,
The 'Bad Penny' raises its head again!  ;)
Have a look on this site: Goffy's_vehicle_electrics
Click on 'red blob' to the left of the items you wish to select, text clicking doesn't select!
May I suggest "Motorcycle batteries", these are all 'Absorbed glass mat' construction, including a 12v or 6v battery with a box to fit it in, if you have a machine requiring a 6v battery.
Some of the LED stuff may be of use to you and others, if you are not worried about "originality".
Re: Small Batteries
« Reply #2 on: May 25, 2015, 07:56:37 AM »
Just bare in mind you can't go too small as it will still need enough umph to turn the starter over - no kicker on the GN as I recall. I think the original was about 12amp/h so that may limit your choice a bit.
guest1406
Re: Small Batteries
« Reply #3 on: May 27, 2015, 12:43:48 PM »
would this work below? I really am awful with electrics.
WESTCO 6V AGM BATTERY
These use the same advanced AGM technology as the 12V batteries above but are intended for use with 6V non-electric start bikes
They have a large 13AH capacity
They are 105 x 70 x 140MM & are a snug fit inside the rubber battery boxes.
(4 1/8" x 2 3/4" x 5 1/2" app.)
Cheers,
Mackenzie
Re: Small Batteries
« Reply #4 on: May 27, 2015, 03:25:36 PM »
Nope, the GN250 has 12 volt electrics.
guest1406
Re: Small Batteries
« Reply #5 on: May 27, 2015, 06:02:15 PM »
How about .. .
WESTCO 12V AGM BATTERY
These use the same advanced AGM technology as the batteries above but are intended for use with 12V non-electric start bikes
They have a 5AH capacity
They are 90 x 70 x 106MM & fit inside the rubber battery boxes.(3 1/2" x 2 3/4" x 4 1/4" App.)
Mackenzie
Re: Small Batteries
« Reply #6 on: May 27, 2015, 08:24:50 PM »
Right voltage, but 5amp/h will probably struggle to start it - if it had a kickstarter then no problem, but the electric boot needs a higher ampage to crank the piston over. Standard is ( I think ) 12amp/h so you are going to want at least 9-10 amp/h and they aren't going to be that small.  You might find the high tech batteries may be smaller but they are expensive. Could you fit a standardish sized battery in one of those custom battery boxes the Chopper crowd use? Would it fit above the swingarm pivot where the airfilter would usually fit? Chrome/alloy if you want it noticed or matt/satin black if you don't.
guest1406
Re: Small Batteries
« Reply #7 on: May 31, 2015, 11:20:44 AM »
With a bit of research i decided to get the "YTZ7S Westco Motorcycle Battery 12V 6Ah (12VZ7S)" for £60.
The anti gravity batteries claim it will start everyday with bikes up to 400cc on 6ah and 130cca. The Westco produces the exact same power output but is a tiny bit bigger (only slightly!) and a lot cheaper! one review said its used everyday for the past two years on his Hornet 600.
Can start making a box now!
Cheers for the help guys!
Mackenzie
