Author Topic: Cheap and Simple Carb Adjusting Tool  (Read 1920 times)
« on: February 16, 2015, 10:38:27 PM »
Hi all. So I needed to set the pilot screw on my dommie carb. But of course, the bike needs to be running, and the pilot screw is tucked away in the centre of the bike.
So, take any old bolt with a flanged head. Cut the threaded part with an angle grinder and shape so that it all you have left is a small stub which will fit the slot in the pilot screw. Then place bolt head in a ring spanner or ratchet spanner, and Bobs your mothers brother  :)
Attachment Expired
Re: Cheap and Simple Carb Adjusting Tool
« Reply #1 on: February 16, 2015, 11:51:54 PM »
nice one tim good thinking  ,how many turns does a dommie carb need  no manual for my own tommy
ps I will have that address this week
« Reply #2 on: February 17, 2015, 08:40:14 AM »
That's great Tommy, thanks.
Im not sure how many turns, as I havnt set it yet. When I took the carb off the bike to fit a new manifold, (from NRP, as the original one had a split along its length), I noticed that the pilot screw was a full four turns out. This definitely is excessive, as it should be somewhere between one and a half and three I'm guessing. I've put the carb back on with it set to two turns out as a starting point, but haven't got round to checking it yet.
The XBR manual recommends two and three quarter. As soon as I figure it out, I'll post it on this thread.
Anybody else out there know the answer?
« Reply #3 on: February 17, 2015, 08:49:39 AM »
I use to own a Cossack 650 ( flat twin) and I remember being shown someones 'top tip' for making sure both the carb slides were lifting at the same time. First he took off the rubber inlet hoses that go from the air filter to the carb mouths and put the bike on it's main stand. Next he took off his boots and socks and sat aboard the bike with a big toe in each carb mouth with the slide just resting on each big toe nail! When he opened the throttle he could feel which slide lifted first and adjusted them! Sounds wierd but it does work!....don't think you'd find it in the manual though!
« Reply #4 on: February 17, 2015, 04:49:09 PM »
That is brilliant! I'm going to have to buy a twin just to try it out  ;D
« Reply #5 on: February 17, 2015, 06:38:25 PM »
Would work on an srx. Would strongly advise some warm up loosening first.  :o
« Reply #6 on: February 18, 2015, 03:51:13 PM »
I use a 1/4 drive screwdriver bit and a 1/4" spanner....be it ring or ratchet !
Same idea really  :-)
« Reply #7 on: February 19, 2015, 01:09:48 AM »
 Yes J, the difference is that you know what youre doing, whereas I'm on a steep learning curve  :-\
« Reply #8 on: February 19, 2015, 07:49:37 PM »
Hi Tommy, Honda commie pilot screw should be set to three full turns out according to manual. I stilll  havnt got round to setting mine up. Jets should be a 155 and 48.  :)
