Author Topic: SRX Gearbox Parts?  (Read 1599 times)
guest1670
SRX Gearbox Parts?
« on: June 30, 2013, 09:26:49 PM »
Hi all.
Been meaning to join for a while, having bought a srx600 back in February. It's been under a cover up until now, whilst I made room in the garage in between working on my other projects. I belong to several other forums, always find them invaluable and have been known to offer a few useful snippets myself too!
Anyhoo, here goes for the first of what will probably be many questions, as I'm doing a ground-up rebuild. I have an '87 1XL, engine stripped, shopping list ready. Main problem is the gearbox which is more or less b*gg*r*d. I was expecting to find some wear on fifth, having read a lot about this being a common problem first, but 3rd and 4th are both badly pitted and shot, making me wonder if the old girl has been raced somewhere in it's 56K mile history. At a minimum then I'm looking at a pair for 3rd, a pair for 4th and ideally a 5th too! I don't mind buying the odd part from Mr Yamaha, but this lot doesn't come cheap and it's only the start!
Anyone got any usable gears or maybe a complete gearbox they could sell me?
Martin
guest1670
Re: SRX Gearbox Parts?
« Reply #1 on: June 30, 2013, 10:00:30 PM »
Hmmm.....
On closer inspection, better add 2nd gear to the list too...
« Reply #2 on: July 02, 2013, 05:43:27 PM »
I have an srx 400 bottom end, although the ratios are slightly different the top gear ratio can be set up to suit the 600 by selection of sprockets on gearbox output and rear wheel
i'm sure the 400 internals will fit directly into the 600 bottom end.
 if all else drop me a line
cheers SteveL
guest1670
« Reply #3 on: July 08, 2013, 08:44:13 PM »
Hi Steve
PM sent!
All the best
Martin
