Author Topic: Velorex  (Read 28430 times)
Re: Velorex
« Reply #16 on: September 26, 2012, 06:13:46 PM »
Done that search already - there are better examples on youtube of all things but most are right hand fitting.  It seems to involve the making of a complex looking bracket that runs much the whole length of the bike too.  Beemer frames are a bit weak for sidecars, as are the forks and - on mine - the brakes (as Graham will testify I am sure).  At least it still has Timken bearings where it matters.
Re: Velorex
« Reply #17 on: September 26, 2012, 06:32:03 PM »
And what with the vintage art, attached, I think you are on to a winner. Chelsea, here you come.
Re: Velorex
« Reply #18 on: September 26, 2012, 07:07:33 PM »
Don't worry, you're only going to take your kids in it.
Re: Velorex
« Reply #19 on: September 26, 2012, 10:09:32 PM »
Steve - what the f**k are you on about  ???
Re: Velorex
« Reply #20 on: September 26, 2012, 11:31:51 PM »
Better choice than sticking it onto an MZ....easier for a start  ;)
Proper sidecar tyres available too, 19" and 18".
It just so happens I have some fittings for BMW....might fit yours.
« Last Edit: September 26, 2012, 11:34:53 PM by 002 »
Re: Velorex
« Reply #21 on: September 26, 2012, 11:59:45 PM »
Excitement here in Lampeter - thinking R80 bevel boxes and stuff.
Take the bike back to R100/7 standard with wider/higher bars and all, 'normal' footrests, lose the fairing etc etc.
Re: Velorex
« Reply #22 on: September 27, 2012, 06:41:01 AM »
I was responding to Rob's suggestion regards potting mix and some nice bulb,...
« Last Edit: September 27, 2012, 12:07:01 PM by Steffan »
Re: Velorex
« Reply #23 on: September 27, 2012, 06:49:58 AM »
I would try it with the standard bevel box first.
Velorex very light.
I did lower the gearing on my Bonnie for The Dragon.......there was no need !
Went around Ireland 2 up towing a trailer and all the gear. No problem !
Popping along at 60-70mph easily.
Re: Velorex
« Reply #24 on: September 27, 2012, 09:20:59 AM »
My thinking is that the R100S was the highest geared of all /7s - they actually reduced the gearing on the RS but made a few internal changes to make use of the higher revs.  It can be fairly high stepping as it is.  What it will need is a new clutch and the rear crankshaft oil seal replacing first however.
I don't know how the standard forks will cope but given the cost of fancy leading links etc, will have no choice but to try.
Re: Velorex
« Reply #25 on: September 27, 2012, 10:31:04 PM »
Several choices to beef up the forks.
Stronger springs
Spacers
Old Valve springs on top of original springs.
Or a combination of the above....within reason.
I have done all three at one point or another and found it can work quite well.
And heavier oil.
Re: Velorex
« Reply #26 on: September 28, 2012, 08:09:45 AM »
I was thinking more about the side to side pressure on what are only 35mm forks rather than the uppy downy thing  :)
It  has a fork brace on mind, they were terrible with only the pressed steel thingy on.
Re: Velorex
« Reply #27 on: September 28, 2012, 09:00:27 AM »
oooooooh! ;D
Re: Velorex
« Reply #28 on: September 29, 2012, 06:41:06 AM »
Ah Yes ! You could do with one of those.
Re: Velorex
« Reply #29 on: September 29, 2012, 08:24:52 AM »
As "brace yerself Sheila" ?
