Author Topic: XBR fuel tap  (Read 1967 times)
oldfarttony
XBR fuel tap
« on: September 12, 2011, 12:38:19 PM »
I have a leaky fuel tap on my '87 XBR and cannot find a replacement for less than about £50. I am considering drilling out the rivet heads and replacing them with either self tapping screws or 2.5 mm bolts to get inside the tap and see whether I can do a repair. Does anyone know of a repair kit to fit this tap? Or has anyone out there done this before? Any ideas or information gratefully received.
Re: XBR fuel tap
« Reply #1 on: September 13, 2011, 07:49:56 AM »
Replacing the rivets with screws or machine screws is a standard fix; and once you get inside you may find that the rubber bit is reversable: just turn it over and it's good as new.
oldfarttony
Re: XBR fuel tap
« Reply #2 on: September 13, 2011, 08:39:28 AM »
Thanks for that. Will sort it today.
oldfarttony
Re: XBR fuel tap
« Reply #3 on: September 14, 2011, 09:23:06 AM »
In case anyone's interested and has the same problem. I have now found that Andy at NRP does a seal kit for the XBR fuel tap. I tried the reversal of the seal but it was too damaged.
