Author Topic: SRX 600 front suspension  (Read 15843 times)
guest1334
« on: August 31, 2011, 01:38:14 PM »
Hi,
I have an [edit] '85 SRX600 1JK import model, needs some TLC... would be grateful for any tips or hints on fork overhaul.
Going to give it ago myself, any gotchas to be aware of?
Need seals/dust cover, can anyone recommend a supplier, Pyramid Parts seem to do a kit, anyone used them?
Reading through forum more progressive springs seem to be the general recommendation, is it just a straightforward swap?
Seen Hagons for £80 a pair, again any good? Any other recommendations?
(This bike has the air valves for preloading)
Back shocks need replacing too, but that will be another topic I think...
thanks
Rafe
Re: SRX 600 front suspension
« Reply #1 on: August 31, 2011, 08:48:36 PM »
Rafe
     I have used Pyramid Parts for seals in the past and had no trouble with them. The kit they do for front forks seems good value too esp as one dustcover off Mr Yamaha is probably the same price as their total kit!. Im hoping to purchase a set of front springs off Hagon, so I will be swimming in the same water as you as far as the springs are concerned, but have heard nothing detrimental said against Hagon products in general. I have a pair of second hand Hagon shocks on the back of my (hybrid) SRX400 and they improved the handling somewhat over the previous (anonymous)pair I had fitted. They are getting quite expensive tho now (approx £130 ish)
When disassembling the front forks you will probably need a tool of some description to hold the internal cylinder to stop it from turning when you undo the bottom socket head bolt that holds it in place. They are normal Yamaha front forks so if you cant get a workshop manual for the 600 then most forks of a similar era will give you the general lowdown on stripping and rebuilding the forks. I suggest you get a copy of the parts list which will give you an idea of how many parts there are involved in the front forks. You can get this off Steve Haywards SRX website (http://www.srx600.net). This will probably get you started but there are enough people on here with SRX s to keep you from getting into too much trouble.
Hope this helps
Ian :)
« Reply #2 on: August 31, 2011, 11:09:29 PM »
Aye Rafe,
Pyramid seals, not had any problems.
Progressive Fork springs fitted with 10w fork oil, fine for me.  ;) Others use Hagon, with no problems.
Hagon rear shocks used to be good, but I did trash a pair in a year on the back of the Duke!  :( Have a pair of Konis on the back of Sally [SRX 600] at present [non-adjustable damping and quite soft springing], which are good and rebuildable.
Tool as described by ian650, definitely makes life much easier when trying to undo the bottom allan bolt:
'T' handle 400mm x 16mm round bar m/s + shaft 600mm x 16mm round bar m/s + 22mm hex head H/T bolt with the thread sawn off, if required [Overall length ~730mm, could be 750mm if you wish]. All stuck together with some weld, as per image attached. Should be self explanatory, I think.  :) Plenty of leverage, if required, a strong enough to take a 'bit of stick'! Airgun helps as well, if you have such luxuries! ;D
As Ian says, SRX600 manual available or the Clymer XT600/TT600 does fine and SteveH's site for the parts lists.
Measure the volume of fork oil when refilling the forks and measure the level from the top of the fork tube as well [just to make sure! ;)].
I hope this helps.
« Last Edit: August 31, 2011, 11:12:00 PM by themoudie »
« Reply #3 on: September 03, 2011, 10:27:06 AM »
I use 15 grade oil (and my forks have the wonderful schraeder valve at the top, so i pressurise to 12 psi) the pressure will only be retained if the seals and sliders are in top nick.
on advice from some expert SRX specialists i fill oil up to 125mm from top of staunchion (with fork fully extended, i.e. block under engine and front wheel off the ground)
not currently using progressive springs.
never had any problems with this setting.
guest1334
« Reply #4 on: September 10, 2011, 09:44:14 AM »
Thanks Ian and Bill,
Pyramid seals here waiting for install (SWMBO has made it clear bathroom redecoration has priority...)
Seen SteveH website, been looking at that and Thumper club site for a couple of years on and off, persuading myself to get back into biking.
Hoping to get that tool made up, a friend has a contact, welding is something I have never tried. No air tools I'm afraid, don't even have a shed nor the £40 a week for a garage around here, so will be working in the street (hoping to get a garage share sorted for the winter). SWMBO on first seeing the bike said "it's not coming in the house!" but should be able to get bits in.
Have a copy of the manual, downloaded via a link found on this site, pdf of a photocopy by the look of it, some of it a bit blurry - is there a better one out there without buying the Yamaha one? Have a pdf copy of the owners manual which is useful too
Thanks SteveL - interesting info, nothing about the fork valves in the manual I have, is it just the caps that are different or is there differences in the rest of the fork assembly?
Bit worried about what I might find when I get these forks apart - dust caps look fairly new so suspect a recent seal/cap change, but something wrong somewhere....
regards
Rafe
« Reply #5 on: September 10, 2011, 12:33:50 PM »
I suspect the manual you have is for the American model (599cc) The air forks were only fitted to the home market SRX (1JK) so you wont see them in the manual. From memory the threads on the caps are different so its not possible to use the caps on the 1XL fork legs, other than that I believe they are the same.
guest1334
« Reply #6 on: September 25, 2011, 06:25:09 PM »
Managed to get one fork cap off, other is being a right sod - not going to be able re-use it thats for sure.
1JK model so cap with valve, no luck in tracking one down today, cant even find a part number - anyone have a source for replacements?
Or one sitting in a tool box by any chance...
regards
Rafe
« Reply #7 on: September 25, 2011, 10:06:17 PM »
Part number for 1JK model is 1JK-23111-00 (Cap Threaded for air valve)
Any half decent Yamaha dealer will be able to get you the part from a part number. Cost unknown!
You really need the correct size socket to get these off without damaging but sometimes time does have an effect ie they get catalytic corrosion with the steel/aluminium alloy.
HTH Ian :)
guest1334
« Reply #8 on: September 25, 2011, 10:59:18 PM »
Thanks Ian, part number will make things easier - now just have to find a half decent dealer.
I was using a six sided 19mm socket which seemed to be the best fit, I'm blaming previous damage...
regards
Rafe
« Reply #9 on: September 25, 2011, 11:23:35 PM »
     :o ::)
guest1334
« Reply #10 on: September 28, 2011, 04:35:55 PM »
Part number 1JK-23111-00 is discontinued, haven't been able to find one in stock or on line anywhere so far. Seems to be a unique part not used on any other models.
Ian can you confirm the 1JK inner fork tube number is 1JK-23110-00? Time to do a bit of cross referencing on Yamaha parts...
thanks
Rafe
guest1334
« Reply #11 on: September 28, 2011, 05:30:47 PM »
Ian, Bill had that fork tool made up - cost about £3 for bolt and rod, and a fiver to be welded up on the spot at the metal stockholders.
Worked a treat!  (Available for loan to anyone around the Brighton area)
Can anyone let me have a copy of the workshop manual that covers the 1JK model please? (Beer vouchers available of course)
I've just measured the spring length at 477mm, manual I have refers to "Fork Spring Free Length (Limit):494 mm (19.5 in)".
So does that mean I'm 17mm under - down to wear?, or maybe wrong springs have been fitted? Theres no identifcation marks  :-\
regards
Rafe
« Reply #12 on: September 28, 2011, 11:09:11 PM »
Aye Rafe,
Pleased to read that the tool was a success.
If you care to send me your email address via the PM facility on this site, I'll send a copy of the manual I use as an attachment to a message.
As for your spring length, I think that you have a pair of worn out springs, they have lost their compressive strength!  :(  A new pair from either Hagon or Progressive Springs with good seals and new oil should prove a revelation.  ;D  You might also consider the replacement of the whole of the front end with something a bit more uptodate FZR400RR! But that can involve a lot more money and phaffing than new springs!  ;)
« Reply #13 on: September 29, 2011, 06:33:48 PM »
thanks
Rafe
If you PM me your address I have a spare fork cap with valve you can have.
Steve
« Reply #14 on: September 29, 2011, 06:44:26 PM »
Rafe
       I think the free length of the fork springs is 475.5 m/m (18.7") which would tie up with your springs
Steve confirm I have the correct info please! (taken off the SRX400 site)
Ian  ???
(Inner fork tube number is correct)
« Last Edit: September 29, 2011, 06:46:26 PM by ian650 »
