Author Topic: Whats this  (Read 2860 times)
Whats this
« on: August 01, 2011, 07:39:42 PM »
- Rattle, Rattle, Rattle
Check Chain - Seems Ok
Take ear plugs out, Engine seems ok
Ok I will check when I am home
- Rattling stops, Rear Brake rather long
Whoops pads have fallen out (Brembo caliper) They have been there three years so I have no idea why they decided to pop out now
Re: Whats this
« Reply #1 on: August 01, 2011, 09:34:35 PM »
I wonder how worn your discs/pads were.  Still shouldn't happen mind.
Could have had an unhappy ending too, glad you are okay.
Re: Whats this
« Reply #2 on: August 02, 2011, 06:51:44 AM »
Very little wear at all, I don,t use the back brake much. The retaining pin and spring clip had fallen out. Not a good design.
Re: Whats this
« Reply #3 on: August 03, 2011, 05:58:37 PM »
Well I have found the problem, on inspection the hole locating the pin has worn oval so the pin retaining mechanism is ineffective and the new pins just falls out as well.
Re: Whats this
« Reply #4 on: August 03, 2011, 10:39:18 PM »
Can they be drilled and have small R-clips fitted ?
Re: Whats this
« Reply #5 on: August 04, 2011, 07:06:53 AM »
Thats an option I hadn't considered, the other is to replace it with an M4 bolt and locknut. The drilling option might be neater
guest1155
Re: Whats this
« Reply #6 on: August 05, 2011, 07:30:26 AM »
r clips are the way forward. i've changed most of the bikes i'v owned to them and never had a problem. I would shy away from a bolt as its ripe for siezing in. Ever tried to get one of thoser stupid 'protective' cap/covers off a nissin calipers' pin after its been on there a while? It's not a lot of fun i can tell you.
Re: Whats this
« Reply #7 on: August 05, 2011, 08:50:00 AM »
The bolt would be stainless so shouldn't be too bad. The R clip approach would need careful drilling, I was thinking I could drill through a 4mm nut, from top to bottom, and use that as a guide. Anyone know where I can get R clips from ?
tj63
Re: Whats this
« Reply #8 on: August 05, 2011, 11:22:17 AM »
If I've understood you right, they use that type of fixing on the Yamaha FZS1000 .
Trevor
Re: Whats this
« Reply #9 on: August 05, 2011, 12:33:56 PM »
Ebay has the answer
Re: Whats this
« Reply #10 on: August 05, 2011, 09:23:17 PM »
Me ?
 Got some small brake pin aRse Clips in my tool box.
guest1155
Re: Whats this
« Reply #11 on: August 05, 2011, 09:46:23 PM »
good plan with the nut, should work a treat.
Re: Whats this
« Reply #12 on: August 07, 2011, 08:40:30 PM »
got a tray of assorted 'R' clips from halfrauds.... not too pricey.
I wirelock my retaining pins
Re: Whats this
« Reply #13 on: August 07, 2011, 09:52:20 PM »
Bugger You !   >:(
I'll put them back in my toolbox then...... ;D
