Author Topic: Please help Re XBR 500 1986  (Read 2942 times)
guest1220
« on: June 05, 2011, 09:30:05 PM »
Seeking a camshaft for my XBR. The original part is 14100MK4700. Honda no longer support these models and camshafts are unobtainable from dealers. Alternatively does anyone know of a supplier of performance XBR camshafts, a little more go will be nice.
Mel
Re: Please help Re XBR 500 1986
« Reply #1 on: June 05, 2011, 09:47:30 PM »
Slightly offtopic but reasonably relevant.....
How polite of you to say that "Honda no longer support these models"
Ian  ???
1 BMW C400X
« Reply #2 on: June 05, 2011, 10:14:30 PM »
They sometimes come up secondhand on Ebay but you take the risk of them being worn too.  Alternatively you could get your cam rebuilt/reprofiled - I haven't used this firm but they have been recommended by another club member.
Joy Engineering Motorcycle Camshaft Specialist
Tel 01279 730 682
The workshop
Ryes lane
 Hatfield Heath
Bishops Stortford
CM2 7BS
White Brothers did a performance cam for the GB500, don't know if that is still available but it would be expensive
pigafetta
« Reply #3 on: June 05, 2011, 10:55:25 PM »
I dunno if this helps but cmsnl.com have got 14100-MK4-710 camshafts in stock. MK4 is listed as the model code for XBR500 but I don't know what the 700/710 is all about. However, since my top end has recently started making horrible maracca type noises I may be finding out very shortly  :(
Anyway, they have 2 left. Heres a linky if you're interested...
http://www.cmsnl.com/products/cam-shaft-comp_14100mk4710/
Dave B
« Reply #4 on: June 06, 2011, 09:44:34 PM »
Dave B
Thats the whole part number !
pigafetta
« Reply #5 on: June 07, 2011, 08:07:02 AM »
What I should have said was I don't know what the difference between 14100-MK4-700 and 14100-MK4-710 is. I didn't realise there were several different ones depending on specific model and year etc.  :-\
« Reply #6 on: June 07, 2011, 08:43:07 AM »
Ah Yes !
Later XBR had auto Decompressor on the Cam.,not operated by a cable.
« Reply #7 on: June 10, 2011, 09:36:53 PM »
hi mel have a look on ebay item no.110698217567 it says the cams they have do gb 500,s not sure how much difference it is to the xbr might be worth checking out  ..........tommy
« Reply #8 on: June 11, 2011, 09:14:05 AM »
I took a look at that camshaft and the description is not accurate, While all the rfcv cams will work on any motor there are differences in the timing, for example the xr600 cam opens at 35' the xbr and gb cams open at 40'. The best bet is to get the cam built up and reground, or alternatively if you can do without the automatic decompressor and wish a little extra performance then a hotcam stage 1 would do the job and are very reasonably priced (available on ebay)
guest24
« Reply #9 on: June 14, 2011, 10:46:34 AM »
I have used KentCams before to reprofile a camshaft and found them to be very good. www.kentcams.com and they list XBR500 for both road and race cams.
