Author Topic: (Twin cylinder) advice wanted  (Read 2534 times)
« on: February 08, 2011, 10:57:30 PM »
Anybody here had an older Yamaha Superténéré?
Are they easy to live with? any foibles?
Re: (Twin cylinder) advice wanted
« Reply #1 on: February 08, 2011, 11:17:28 PM »
I'll speak with a man who has one!
Having spoken with a 750 owner who thought they were really good, the traded it in for a 900. That apparently was a positive leap and even better than the 750. However, I shall get an update and report back.
In the meantime have you Googled for a UK/German club?  ??? This is one I've selected: 'Super-Tenere International'
« Reply #2 on: February 08, 2011, 11:23:29 PM »
Cheers for that, the site contained an interesting question from one owner, here's an edited version:
"last week i changed a few things on my super from '90
* left hand switch (2nd hand from a 92er)
(snip)
it all works great, except for my test ride....
now the high beams switch on when pulling the clutch lever
(snip)
i really could use some advice here!
has any one got an idea??"
I know I shouldn't laugh, but waaaaahhahahahahahahaha  :D :D :D :D :D
guest29
« Reply #3 on: February 09, 2011, 10:10:15 PM »
As it happens I've owned one for a year there are a few  points to watch out for  are worn out emulsion tubes (rough running & horrendous fuel consumption), welded front sprocket & nut, standard reg rectifiers are considered weak as are the fuel pumps . Oh and the twin disk set upon the front isnt brilliant but can be improved upon fairly easily other than that they're nice bike to ride  ;D
ps lights are a bit dodgey (found out after riding the bike home on an unlit road after buying it , I'd thought all the bulbs had blown ::) )unless you can find one with with halogen h4's again can be sorted with uprated bulbs and auxilliary lights
« Reply #4 on: February 09, 2011, 10:51:27 PM »
Cheers for that.
Is it (roughly) the same engine as the TRX/TDM? I know they have emulsion tube issues.
« Reply #5 on: February 10, 2011, 09:58:42 PM »
Cheers for that.
They are roughly the same, the TRX a bit rougher.
I fitted a TDM850 motor to mine when I owned one, straight forward as I remember it, only had to strip and swap some carb linkages.
The TRX has a longer mainshaft so the chain will clear the wider back wheel.
All engines vary in firing 180*, 270*, model that changed in different years, etc.
