Author Topic: GPS advice needed  (Read 5977 times)
Furry John
Re: GPS advice needed
« Reply #15 on: February 07, 2011, 03:53:41 PM »
Quote "The dedicated motorcycle units from the well known brands out there are IMHO overpriced and from what I've seen don't always deliver seeing as they're supposed to be bike specific. I'm thinking here of the failed power connectors on the TomTom Riders" Unquote
Hi Si, GC
I have used a TomTom Rider 2 for the last 3 years now, this is it's 4th year. It has done 3 trips to Spain/Portugal on the R75 BMW, numerous trips in Britain on the Velo Thruxton and this will be its 4th. Dragon (I Hope) on the DR. I have had no battery power problems, it runs for around 8 hours with no power connection. In the second year the Velo's vibration and a thin metal homemade mount managed to destoy the battery connection for in use charging, a phone call to TomTom with the serial number of the Unit and 2 days later a new mount arrived, no return requested of the old one so I use that for less than 8 hour runs. Every time I connect it to the PC it updates its maps and for £44/annum I get a complete new updated set of Western European maps every 4 months. The second mount has slightly stronger springs which prevent the vibration reaching the little pins in the back. I agree the mount is the weak spot but as long as consideration is given to limiting the vibration the mount is exposed to, the unit seems to be quite good.
Using Tyre for itinerary planning and downloading to the TomTom gives you an easy choice to add your own sections to routes, avoid bits of road you do'nt want to use or simply go your own chosen way with guidance.
The Bluetooth is a mixed blessing, if you are running an itinerary and change it enroute the bloody GPS is whingeing away in the headphone until you stop and put it right. I keep it turned off. The messages about connections can be an on screen annoyance, you can guarantee that just when you have a tricky bit to follow the bluetooth screen message will come up and tell you you have no connection, you know this anyway, but you cannot turn the messages off and they hide a percentage of the map on screen. The mobile phone stuff is totally uneccesary, who rides a bike and makes and receives bloody phone calls, only pan posers. I had hoped that the new versions of the Rider would correct the faults of the old but they just seem to have limited the functionality (keeping all the ruddy bluetooth) to make the units cheaper so when this dies I will be looking at Garmin I guess.
HTH
Furry
« Last Edit: February 07, 2011, 03:58:11 PM by Furry John »
Here I go again!!
« Reply #16 on: February 07, 2011, 06:16:14 PM »
Mobile phones, especially with built-in GPS receivers are an other option. I have used a mobile a number of times when my dedicated satnav has been playing up, but the small screen size can be an issue when on a motorcycle. Also, unless it has a nice big touch screen, it can be awkward to use with gloved hands.
The other thing to bear in mind is that the majority of the satnavs and mobile phones have a very short battery life so a power supply from the bike's battery is a necessity unless you're doing very short journeys or you're disciplined enough to put the device into standby (if you can do so easily with gloves) for long sections of road, such as on motorways or major A roads, where you know there isn't going to be a turning for a long while.
HTH,
Simon
One of the display modes on the SatNav software on my phone simply displays arrows indicating direction and the distance to the next junction. This is much easier to view on a small screen
I tend to use it to get through/round cities, for the rest I use a map. As for waterproofing it goes in the tank bag. Its not ideal but difficult to beat for the price
guest868
« Reply #17 on: February 08, 2011, 09:19:56 AM »
Should you deiced to go for a water proof case, I can strongly recommend Overboard- http://www.over-board.co.uk/catalog/index.php
