Author Topic: Petrol stovers shudder while Pat is in good company  (Read 8387 times)
Re: Petrol stovers shudder while Pat is in good company
« Reply #15 on: December 16, 2006, 09:17:26 AM »
Of course we don't really *need* to know as pretty much any liquid fuel will work in a nice varifuel/whisperlite etc etc, of course if you have one of these fussy camping Gaz stoves.... ;)
Lots of you have been glad of a cuppa made on it though :-) Hey GC
« Reply #16 on: December 16, 2006, 06:48:50 PM »
« Reply #17 on: December 17, 2006, 08:19:35 PM »
LOL, I was just about to post the same link.
Coleman fuel is (at the very cheapest) £3.99 a litre here, but US stovies laugh when you tell them that because they pay about £1.00. Apparently there's some substance that car painters use that can be used instead of Coleman fuel and is almost as good (panel wipe?), but I haven't tried it yet.
After the latest stove debacle at Llanthoney I stripped down the stove and found the generator tube to be mucky. When it was reassembled it ran like a blowtorch... which didn't assuage my sense of shame one bit. My mistake (in retrospect) was in trying to run it at simmer temps, which an MSR doesn't like when using petrol and likes even less when you're using paraffin. It did manage supper, half of breakfast and two coffees before going phut though.
Funnily enough I picked up a Gaz stove in its neat blue tin the other day for £1.00. Despite being at least 20 years old it lit and ran beautifully and yes, I can see the advantage of gas during the summer months, it's way easier (right up to the point you run out of fuel).
As for Scott, he used containers with leather washers which allowed the paraffin to 'creep'. This problem was exacerbated by the positioning of the bright red paraffin tins on top of his depots to act as guides. Over the course of the many months they were there they went through countless expansion and contraction cycles as the temperature varied. He found that he had lost up to a third of his fuel stock. Amundsen, on the other hand, had his tins sealed with metal caps that were then soldered into place. Apparently one of his depots was rediscovered in the 80s and the fuel tin was still full.
« Reply #18 on: December 18, 2006, 07:46:37 AM »
Thanks GC, I knew I read something about it.
So, how does one go about soldering a can of petrol closed? A bit of historical research will probably find the guy who did it. He's the one in the pictures with no eyebrows!
« Reply #19 on: December 18, 2006, 09:38:04 AM »
Set up n+1 cans of petrol with flux ands solder bits round cap.  ignite first with trusty paraffin blow torch.  When you get back from the Burns unit the others will be scattered around the garden, but soldered closed.
Usless bit of info that probably explains alot department.  My Dad as a kid used to see his dad checking the cans of (black market) petrol to see how much was in them - to do this he would hold a match high above the can and look for the reflection in the petrol... My Dad decided to check a can once and put the match close into the can - resulting in a rather large burnt patch outside the house and a very lucky Dad...
« Reply #20 on: December 18, 2006, 01:53:53 PM »
Of course the other thing about Amundsen was he was in and out relatively quickly whereas Scott took so long with manhauling that he got caught by the weather.
