Author Topic: indicator problem  (Read 1578 times)
guest668
indicator problem
« on: April 16, 2010, 08:39:57 PM »
indicators on my srx wont flash unless the engine is excelerating...does anyone know why this is? can it be a sign of a fault rectifier...?
Re: indicator problem
« Reply #1 on: April 18, 2010, 08:26:56 AM »
You are short of power somewhere.
Does the headlight work? What's the voltage at the battery engine off, idle and half throttle? How many volts across the flasher relay (which I assume is mechanical?)?
