Author Topic: XBR: bar risers advice needed  (Read 4286 times)
BrendanO
  • Procrastinating in Embra
« on: October 22, 2009, 08:33:02 PM »
Hi
As my Dad is downsizing, I'm now getting to ride his XBR. Lovely, but don't really like the dropped bars.
Anyone know if I can get bar risers that clamp onto the fork tubes (rather than drilling holes into the top yoke)?
Or any other alternative tricks? Would prefer not to drill the top yoke. Have seen Helibars, which are lovely, but nearly £300!!!!!!!!!!
Ta
Brendan
(PS My Dad at 72 is now on a CB250 Nighthawk)
non-thumpers CX500EC, NTV650P
Re: XBR: bar risers advice needed
« Reply #1 on: October 22, 2009, 09:32:37 PM »
As far as I know Honda CBX550 F2 handlebars fit straight on.  Most of the XBR cables will still fit but you may need to carefully re-route and check throttle cables are not being pulled on full lock.  I think you may have to replace the choke cable - you may have to make one up.
Gives a useful rise over the standard bars.
« Reply #2 on: October 22, 2009, 10:06:59 PM »
Yep, the CBX550F2 bars do fit straight on and they give a decent improvement in handlebar height.
guest288
« Reply #3 on: October 23, 2009, 06:17:24 AM »
My xbr came with risers- I've put the standard ones back on- they clamp on the top of the tubes and give about 2 inches in height- I'm no longer using them, if they would be any use?
pigafetta
« Reply #4 on: October 23, 2009, 09:16:00 PM »
Raask make those clip-on risers. They do them in M&P Direct for about £45 a pair.
BrendanO
« Reply #5 on: October 25, 2009, 01:02:02 AM »
Thanks for quick responses folks! All very useful, and exactly the advice I needed!
B
« Reply #6 on: October 25, 2009, 03:56:57 PM »
Without wishing to be to rude to Dave500, if you want to go the CBX bar route I think I've got a set here you can have. I think one of them has a slight bend, but I never noticed it when the bars were fitted.
« Reply #7 on: October 27, 2009, 08:02:31 PM »
hi you can also use honda vf 400/500  clip ons they give a nice riding position ........yoshi
BrendanO
« Reply #8 on: November 07, 2009, 06:08:32 PM »
Ta Tommy!
Am still on the case, having had a couple of initial pm's back and forth! Feel this should be an easy upgrade now, ta to membas!
B
