Old Engine Cleaning
Pages:
3
Topic: Old Engine Cleaning (Read 13495 times)
turkeyuk
Re: Old Engine Cleaning
Reply #15 on:
November 03, 2009, 03:23:22 PM »
Yep no worries mate, cheers
Regular
Reply #16 on:
November 04, 2009, 02:32:56 PM »
shame you dont want to strip it down first. ive just had a set of cases from a 4 cylinder suzuki dipped and cleaned. total cost, 40 quid, but look at the results. shame i didnt take some before pics, but just imagine that its a motor that hasnt been stripped and cleaned since it was new in 1991,
Reply #17 on:
November 04, 2009, 11:59:11 PM »
This the last SRX engine I did..I basically wire brushed it as much as possible on the "roughish" casting parts and rubbed down the polished parts. Then I sprayed it with ZINC OX cold galvanizing paint. This paint seems very durable if left to cure for a few weeks.
http://www.fdev.co.uk/html/galvanizing_spray.html
guest146
Reply #18 on:
November 06, 2009, 06:08:43 PM »
I am intrested to know what vapour blasting is.
Ken
turkeyuk
Reply #19 on:
November 06, 2009, 06:31:43 PM »
Quote from: kerabo on November 06, 2009, 06:08:43 PM
Ken
Hi Ken,
i have a Vaqua Blast cabinet which is like a bead or shotblast cabinet but uses a water, fine glass bead & detergent substrate which can be heated for better cleaning properties, this mixture is then high pressure pumped & mixed with 60 psi of compressed air to produce a water jet capable of thoroughly cleaning and in some cases de-burring items such as plastics & light alloys with no detriment to the surface. The finish is a silky sheen with no pitting or abrasive action at all. For this reason it is not good on very dirty or painted items which should initially be degreased or paintstripped. We finish the process with rinsing, drying & application of ACF-50 or corrosion block fo a long untreated shelf life. If an item is to be painted, powdercoated or polished then bead blast or acid dipping is ok as you need an etched surface for those refinishing processes (both of which i also do) Vapour blasting in my opinion looks fantastic if you want an unfinished alloy look to your parts. I have more pics of car & bike parts if anybody wishes to see more, hope this helps confirm the process as being more than 'steam cleaning' which is often what i am asked if it is?? Cheers, Paul.
guest288
Reply #20 on:
November 07, 2009, 09:26:31 AM »
Hi Paul
that sounds exactly what I'm after- unfinished but clean look, should look good in a freshly powder coated frame. I'll have to get Xmas out the way, but it's my birthday in the new year so maybe I can convince the missus it's a present...
turkeyuk
Reply #21 on:
November 07, 2009, 07:58:07 PM »
Best of luck on that one Dave
hope to meet you in the new year! i may be someway closer to finishing mine by then to catch you up a bit.
Which also depends on if ive been a good boy as my birthday is in the new year too & i would like some goodies for my xbr
seeyou then
guest288
Reply #22 on:
February 06, 2010, 06:45:05 PM »
Hi Paul
Been really busy with work lately- does the offer of vapour blasting my engine still stand? I'm in Essex, so I'd travel up to you in the morning, and back in the evening..
turkeyuk
Reply #23 on:
February 07, 2010, 10:47:31 AM »
Hi Dave, yes no problem i would be glad to help, let me know when you plan on coming and i will set asside time for it, cheers, Paul.
turkeyuk
Reply #24 on:
February 07, 2010, 03:49:29 PM »
little pic for you
guest288
Reply #25 on:
March 15, 2010, 11:38:23 AM »
Hi Paul
How about April 10th? I'm a way the week previously, so providing I can strip the perishable bits off, like hoses etc. I'll also try and spray a nitromors solution to help it along a bit. Let me know what you think.
Dave
turkeyuk
Reply #26 on:
March 15, 2010, 11:51:31 AM »
Hi Dave, im moving that weekend
anytime after should be fine, cheers, paul.
guest288
Reply #27 on:
March 15, 2010, 01:28:25 PM »
Haha! Ain't that just the way? No worries Paul, I'll wait till you've settled in a bit, let me know when you have a bit of time- Weekends best for me though, thanks, Dave
turkeyuk
Reply #28 on:
March 15, 2010, 02:02:36 PM »
i know mate, any weekend after that should be Ok matey, cheers
guest288
Reply #29 on:
March 15, 2010, 06:14:08 PM »
Ok cheers Paul, I've started trying to loosen some of the crud on it in anticipation....
Pages:
3
Old Engine Cleaning
