Author Topic: Old Engine Cleaning  (Read 13487 times)
guest288
Old Engine Cleaning
« on: October 18, 2009, 06:45:16 PM »
Hi Guys
I'm trying to clean up my xbr engine from all the salt corrosion and muck from the past few years. I don't want to split the engine as I know its running well. I was thinking of getting it blasted but that would leave it a dull grey colour. Ive tried alloy cleaner, wire wheels, all sorts of stuff but it still looks pants. Any other ideas for cleaning? If I got it blasted could I paint it with a high temperature paint? Originally I was thinking of silver, but what about black with polished cases? What do you think?
Dave
guest288
Re: Old Engine Cleaning
« Reply #1 on: October 21, 2009, 08:40:50 AM »
Ok, so I've been soaking the thing in Gunk, and with a nylon brush the worst of it is coming off. Its not coming up very bright though, which is really what I was after. Anyone else had this?
« Reply #2 on: October 21, 2009, 05:15:01 PM »
 all the cleaning agents aren't as good as they used to be- probably some european law about being able to drink a couple of litres without dying.
 i used nitro-mors (not as good as it was) and scrubbed it onto an ally petrol tanks with wire wool.
 i won't come up gleaming but it should get all the crap off ready for polishing to whatever degree you want. one tip; wear gloves and long sleeves, it burns like a bugger!
turkeyuk
« Reply #3 on: October 21, 2009, 07:06:44 PM »
hi Dave, if you can fabricate some covers for your inlet & exhaust ports & seal them well plus your crankcase breather & oil hose unions i can vapour blast it for you?
guest288
« Reply #4 on: October 22, 2009, 06:12:18 AM »
That would be great- I have the ports blanked already, just need to seal the oil unions and breather. Maybe I can get that done today or tomorrow- where abouts are you?
turkeyuk
« Reply #5 on: October 22, 2009, 08:16:21 AM »
Im in Lincolnshire near Louth
guest288
« Reply #6 on: October 22, 2009, 10:24:13 AM »
Ok, I'm in essex near the dartford crossing- I would have to bring it up in the back of my works car, I work quite a bit at the weekend so i'd have to let you know when I can make it if that's ok?
turkeyuk
« Reply #7 on: October 22, 2009, 01:35:37 PM »
Hi Dave thats no problem, i work from home so anytimes good for me
guest288
« Reply #8 on: October 23, 2009, 06:14:02 AM »
Ok, thanks. I'll have a word and see when I can bring it up to you- how long do you think it will take? Would I leave it with you and return to pick it up? I take it you would like it as clean as I can get it?
pigafetta
« Reply #9 on: October 23, 2009, 09:14:52 AM »
Hi Dave
I've used High temp aluminium paint on my CB900 casings with matt black VHT on the barrels. The
ally paint looks pretty good and hasn't fallen off yet.
Dave
turkeyuk
« Reply #10 on: October 23, 2009, 10:04:13 AM »
Hi Dave, i can do it while you wait, if you allow 2-3 hours for it to be done, it sounds like you have done quite a bit regarding paint removal & so on, if it is bare alloy it will come up well. If it is as clean from oil & grease etc as possible that will be ok.
« Reply #11 on: October 24, 2009, 05:47:14 PM »
dear Mr turkey
I'm in norfolk, and planning a visit to batemans brewery soon, would it be possible to bring my srx lump up to you for a wash and brush up?  (I assume you must be near Cadwell somewhere?) and could you let me know the cost?....thanks in anticipation
Steve
turkeyuk
« Reply #12 on: October 24, 2009, 06:15:57 PM »
Hi Steve, no probs, im not far from cadwell, as ive said to Dave i can do it while you wait or you can drop it off for a few hours, if the engine is whole then every possible opening has to be sealed & air/water tight in order for it to be done & degreased as best as possible & paint stripped if you are wanting a bare alloy finish. I usually charge £100 for an engine in individual pieces as it takes longer, but as i can get a single lump in the cabinet in one go id say £50 to fellow members, cheers, Paul 07931 904279
« Reply #13 on: October 24, 2009, 08:01:05 PM »
Good man Paul....I'll be in touch.....cheers
guest288
« Reply #14 on: November 03, 2009, 02:54:39 PM »
Hi Paul
I may have to make it in the new year- the run up to xmas is busy for me, is that ok?
