Author Topic: Recipe for a de-greaser  (Read 5075 times)
KirriePete
Re: Recipe for a de-greaser
« Reply #15 on: July 15, 2009, 05:41:51 PM »
Anybody got a 1" cork??
Only after a long ride in the cold and wet.
Somebody had to do it ........
« Reply #16 on: July 15, 2009, 09:56:42 PM »
Aye Pat,
Go along to forensics and ask if you can rake through there flask stoppers. If you don't have the 'bottle' for that, then try any hardware emporium for a basin plug and give it a shave with a Surform, a rasp or a course old bastard file. NO! :-X I wasn't insinuating a referral to any actual or mythical TC member, past or present! :)
I wish you success.
« Reply #17 on: July 16, 2009, 10:09:20 AM »
Will a demijohn cork work?  I have some of those undrilled I think - if not Morrisons may have some.
Infact you could run a bolt through the airlock hole on a drilled one and tighten up against the cork thus trapping it even more firmly into the port.
« Reply #18 on: July 16, 2009, 06:31:57 PM »
That's a good idea Rog and Bill. The weekend can't come soom enough now.
« Reply #19 on: July 16, 2009, 11:14:53 PM »
I wanted to keep the motor whole whilst cleaning, but I can't get the sheared exhaust studs out the head which means I can't bolt down the blanking plates to seal the motor off. Anybody got a 1" cork??
WHY ?      Wouldnt it be better to sort the studs out first !
Then worry about cleaning and painting.
« Reply #20 on: July 17, 2009, 05:56:14 AM »
That'll mean removing and stripping the head to take it to Brian North, then fefitting it to clean the motor, then stripping it to paint/sort out. I'm [being lazy] trying to cut out a stage. ;D
« Reply #21 on: July 17, 2009, 06:53:58 PM »
Aye, you'll get yer fingers burnt laddie! ???
Ta ra, Bill.
robG
« Reply #22 on: July 17, 2009, 07:09:42 PM »
Better to sort it out now ,old boy. Bound to go the way of the pear otherwise. :'(
Rob .
« Reply #23 on: July 17, 2009, 10:56:18 PM »
Bloody Hell ! YOU are making work for yourself !
« Reply #24 on: July 19, 2009, 01:28:15 PM »
 just a thought;
 is diesel okay on the rubber seals on the bearings and brakes?
