Author Topic: Double Thumper Question  (Read 1020 times)
« on: April 16, 2009, 02:13:57 PM »
Well sort of anyway...............
I have discovered that Armours make a 2-1 system for my old Beemer, it crosses over where the balance pipe normally goes apparently.  In Stainless.  Either right or left handed.  Would look v v trick, weigh less, helping both engine and braking, mean cheaper replacment (single) silencer) and did I mention it would look trick, esp now I have the dual plugging.  What do you reckon then ?
Re jetting, insurers, etc.  Any other implications ?
And it would look trick.
Re: Double Thumper Question
« Reply #1 on: April 16, 2009, 03:01:40 PM »
The big question is - will it look trick?
robG
« Reply #2 on: April 16, 2009, 03:16:21 PM »
Probably look very trick . Don't see an issue over insurance .I would think armours would advise regarding jetting issues,I don't see a problem .It may give a bit more mid range as well .
Above all it would look very trick .
Rob .
KirriePete
« Reply #3 on: April 16, 2009, 03:18:39 PM »
I wouldn't do it
unless it looked very trick, that is.
« Reply #4 on: April 16, 2009, 05:14:26 PM »
Must be v v trick to be worth the effort in my book, very trick just doesn't do it and I wouldn't get out of bed for a plain old every day trick.
If you're sure it's v v trick, then I suggest you knock yourself out.......
.....DUDE!
« Reply #5 on: April 16, 2009, 10:42:00 PM »
Yes I have heard of these and IF i had a road going Beemer I probably would fit one.
And it would look VVV Trick !
With a nice Gold Star silencer,also in Stainless.
I would imagine a little more mid to top end power !
Mind I also think a pair of Norton Pea Shooters would look Trick Too !
« Reply #6 on: April 16, 2009, 10:57:17 PM »
When the Sito silencers wear )rust) out Peashooters are definitely on the agenda.
Of course with the 2-1 only one Peashooter would be required............
Cheers,
robG
« Reply #7 on: April 17, 2009, 06:59:28 AM »
How about a stainless Conti ?
Rob .
